Thread: normal map support in LW9.5?
    Registered User aSkeptic's Avatar
    May 2006
    caledonia ohio
    155
    Is normal mapping supported natively or would I need Marvin Landis's plugin?
    May 2006
    France
    3,959
    LW 9.5 has a node to read normal map in tangent space,
    but no native tool to bake it,
    Normal Map Create from Marvin can do it,
    from an hires mesh in the uv map of a lowres mesh in Modeler,
    http://amber.rc.arizona.edu/lw/normalmaps.html
    Denis.
    May 2006
    caledonia ohio
    155
    Thanks dpont!
    Washington State, USA
    2,880
    You can do world space normal maps natively in LW.
    BryPhi made a video tutorial showing a technique I used on a project recently:
    http://www.spinquad.com/forums/showt...=normal+baking
    It looks like his site is down though. If you PM me, I have a copy of the vid I can share with you.
    Here's a brief description of another method that I haven't tried.
    http://www.newtek.com/forums/showthr...rmal+Map+nodal
    Los Angeles
    7,125
    You can apply a shader node by TrueArt called Normal Pass on all your objects to get world space normals. It's part of TrueArt's Node Pack which you can download free. We've been experimenting with Normal Pass to allow us to interactively enhance and even, in some cases, to completely change lighting using Fusion. Very powerful technique.
    DRG
    Los Angeles
    7,125
    Correction: I'm told that we're using proprietary plug-ins for this now, but even so, our initial tests used the Normal Pass node and it worked very well once we figured out how to use it in Fusion.
    DRG
    Super Member H_Molla's Avatar
    Cairo, Egypt
    349
    Greenlaw, can you show example of your node work flow for exporting the normal pass render output ??
    do you use Dpont buffer saver as i guess ?? cause this is the only logic way till LW support that direct..
