Thread: configuration files
    configuration files
    hi,
    how can I have LightWave save configuration files to a locations other than the current one? ( default: C:\Documents and Settings\my_name\ )
    the reason for asking, I want differet configs for 9.2 and 9.5....
    I thank you very much for your help!
    How Old? Really? Aww Heck colkai's Avatar
    Staffordshire
    7,804
    I run LW 9.0, 9.31 and 9.5 on the same PC, all you do is alter your config line in your shortcut.
    G:\Lightwave_9-5\Programs\lightwav.exe -pG:\Lightwave_9-5\Configs -cG:\Lightwave_9-5\Configs
    G:\Lightwave_931\Programs\lightwav.exe -pG:\Lightwave_931\Configs -cG:\Lightwave_931\Configs
    Would be two shortcut paths for Layout in 931 and 95 - with similar for the Modeller exe file.
    Too old to die young.
    Hi colkai,
    I thank you very much for your post, I am not an expert at LightWave…
    What config line do I have to alter, where can I find that shortcut thingie?
    (shortcut path)
    thanks
    Super Member OlaHaldor's Avatar
    May 2008
    Norway
    974
    Create a shortcut on your desktop. Rightclick it, "Properties".
    Under the Shortcut tab, you should edit the "Target" line.
    edit: typo
    3D Generalist
    Threadripper 2920x, 128GB, RTX 2080 Ti, Windows 10
