Thread: How can I render just the object shadow?
    I have a kid's playset against a ground object and need to render the playset and the playset's shadow separately. How can I do that? Rendering just the playset is obviously no prob but how can I get a render of just the playset's shadow with no playset or ground? LW 7.5. Thanks!
    3D Mac Maniac Scazzino's Avatar
    Boston area
    2,554
    Set the alpha of the ground plane to use the shadow density... that should render the shadow to the alpha channel which you can then use... if that's what you mean...
    MikeS [LWProfile] 30+ Yrs of Award-winning Media DreamLight.com
    Drag-and-drop-dead-easy™ ScreamerNet - DLI Constellation
    BOOK - Creating a 3D Animated CGI Short & 3D CGI Short Films & DLI Blog
    Unregistered Guest Sarford's Avatar
    Feb 2006
    Amsterdam
    1,187
    And set the playset to 'unseen by camera'. That way it will still render the shadows but you won't see it.
    Also, you can try to use the .psd exporter form the image filters tab. With that exporter you can toggle which passes you want. Not a real passes exporter but good enough for these things.
    MacBook Pro quad core 2,6Ghz, 8Gb ram
    Mac Pro dual Intel quad core 2.8 Ghz, 8Gb ram, Quadro 4000
    my website and 2011 showreel
    http://www.simonglas.net
    Thanks guys! It worked great!
