Results 1 to 8 of 8
Thread: How to UVmap a racetrack?
    Used Register doimus's Avatar
    Oct 2003
    Croatia
    286
    I'm trying to develop some low-poly modelling skills, and I'm currently learning the process of creating a race-field.
    While I'm aware of the usual UVmapping process (mainly for square architectural objects), I don't understand how to map a longitudinal object with repeating texture (the track itself).
    In other words, how do I make my square texture flow along the winding road?
    Step 1: the track & the texture
    Step 2: ..... umm?
    Step 3: profit.
    What do I do in step 2?
    Dreamer MooseDog's Avatar
    Mount Whoville, VT
    1,438
    Streetwise
    this should do the trick
    We are pirates, we are artists...
    Blog
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    IMO, I think it would be easier to simply create seperate textures for your curves. If not, you'll be stretching them in odd directions and sizes, thus rendering very unnatural results.
    .. or ..
    Follow MooseDog's link. Both will do, but the tutorial is a better way.
    Playing guitar is an endless process of running out of fingers.
    Hastings, New Zealand
    7,731
    If you rail extrude the track you can create your UV coords at that time. Make sure you actually create and apply a UV map to your template poly before rail extruding. Now when you rail extrude youll see the UV options unghosted.
    Oct 2003
    Croatia
    286
    Thanks for the tips, rail extrude worked like a charm. I kind of wondered why is UV option always ghosted there, now I know...
    7,731
    Youll find that this is the case for many other tools
    What the others said, thats pretty much the best solution.
    There are some other more complicated but also quite interesting ones that you can use if you happen to run into problems with this method (for whatever reason that may be)
    A little OT:
    back in the 5.6 days, when LW did not have native UVmaps yet (there was a plugin but I cant remember its name anymore), we had a game engine that would load LWOs including textures, etc (yeah it worked with projected texturemaps actually).
    So we had the job to make this:
    http://www.mediastudio-graz.com/html/msg_avl_eng.htm
    So we did not have any UVmaps for the road, but had to make an 8km course. There was no way that we could fit a single texture for the road into texture memory back then (I think the cards arround that time had 4MB memory, or so).
    So what I did was that I disconnected the part that made up the road (and some of the grass arround it too, I think)and straightened it out. Then I applied the road- surface to the straight version so that the road would tile nicely and morph that straight version back into the curved one. Morphing the road back into shape would deform the texture as well and make it "follow" the curves of the road.
    Anyway, doing this was quite a chore, as I had to manually rotate every single section of every curve in the road until it was straight. It still did not take that long, which was partially thanks to the polygoncount being rather limited back then...
    The video on our page only shows part of the whole thing and the animation is actually a manula camera- flight. The real camera motion was computed by a separate simulation computer that a german company had built.
    CU
    Elmar
    Yes, my Avatar shows a volume rendering...
    VoluMedic Creative Edition only USD 299 !
    www.volumedic.com
    Jan 2007
    Germany
    32
    Hello,
    i found this tutorial very useful and it explains all necessary things for games mapping imho:
    http://www.robinwood.com/Catalog/Tec...LWUVStart.html
    Its worth working through it from a to z.
