Results 1 to 15 of 15
Thread: DPKit Particle Info
    Super Member LightFreeze's Avatar
    Sunny Scotland
    911
    DPKit Particle Info
    Hi Dennis I was looking for some info on the Particle Info node but there is none available on your sight.
    I was trying to get a clone to use a specific particles attributes to see if there was a way to do a crowd sim as discussed in this thread
    I noticed on your site that you show an ObjectID node but I can`t find it in the DPKit, should I be looking elsewhere?
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Jun 2005
    Reading UK
    3,131
    ObjectID node
    This is one of James Willmot's I believe, but I don't know where its hosted anymore. He also created a time node which I was searching for, but that's gone too
    i7 X3930/32GB/Quadro 4000
    Sunny Scotland
    911
    lucky you, I have the time node you mentioned but not the ObjectID node, you think its OK to post it?
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Jun 2005
    Reading UK
    3,131
    mmm...and I may have the object ID node. I'll PM the author and get permission.
    Traitor
    Perth, Australia
    453
    http://www.symmetrix3d.com/index2.php?page=plugins.php
    You'll find the ObjectID node there.
    M
    Sunny Scotland
    911
    Thanks,
    @stevecullum - is there a difference between the native time node, DPKits time node and JamesWillmots?
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    May 2006
    France
    3,922
    There's no Time node in DP Kit,
    but a few nodes with a time scalar input,
    for time output, I currently use a Constant node
    with a very simple envelope and 2 keys,
    key1: t = 0.0 -> value 0.0
    key2: t = 1.0 -> value 1.0
    and End Behavior set to Offset Repeat,
    then it can be scaled for speed,
    or you can add an offset.
    Denis.
    Jun 2005
    Reading UK
    3,131
    I didn't think there was a native one either!
    Sunny Scotland
    911
    don`t know what I`ve been drinking but I better stop, your both right, no dpkit one and no native one.
    did you get word if its ok to post.
    As a scripter myself I know I wouldn`t care if someone posted a script of mine that I had posted into the public domain.
    and there was no readme with the time node forbidding reposting so here you go
    JamesWillmotts time node
    Attached Files Attached Files
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Sunny Scotland
    911
    Denis do you think this is possible,
    item info node with a "Clone ID" output, outputs the integer x if self has a (x) in the name or -1 if it doesn`t
    and an ID input to the particle info node so you can get a specific particles attributes?
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    May 2006
    France
    3,922
    Quote Originally Posted by LightFreeze View Post
    ...item info node with a "Clone ID" output, outputs the integer x if self has a (x) in the name or -1 if it doesn`t...
    Sure it is possible, but too much specific, I would not code it
    for general use, but I know there are request for scriptable
    nodes.
    ...an ID input to the particle info node so you can get a specific particles attributes?
    Convert the emitter as a Partigon object,
    and use Point Info node instead, you can select
    the point index, then cloning the object will offset
    the point index.
    Denis.
    Sunny Scotland
    911
    thanks Denis, I`ll try that instead
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Sunny Scotland
    911
    Sorry Denis, I`m not getting this, I can get clones to track the positions of the partigon points using the point info but I can`t index into the particle info stuff like age, force etc, could you post a node tree maybe?
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Sunny Scotland
    911
    I noticed you posted this in another thread,
    Particle Info node could not be used to "FXLink"
    an object to a particle, since it ouput the ID
    of the nearest particle instead of a constant
    given ID/index.
    I think I get it now, particle info is for surfacing, you cant use it for motion, is that right?
    VueScripts.com
    __________________
    win32
    core2duo E6500
    GTX 260
    Jun 2005
    Reading UK
    3,131
    Yes - he's fine with it. Thanks for the Time node
