Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
Thread: What a monster Tricaster Studio is !!!!
    Dec 2007
    Malta
    126
    The big truck in a small box is more than true. Recently I built some circuits and purchased some Baluns and now i have a professional OBU with high quality SVHS signal, tally and talkback with camera persons ( both ways director - operators). All this through a professional CAT 5/6 cable. Nobody would believe this was not a high end professional big TV production truck performance. I am still amazed and still not could not beleive what I have been loosing before purchasing the tricaster. Anybody interested and with the knowhow of building a circuit from may ask for the artworks which i have produced (my copyright). The circuits consist in : 1) Tally relay switching 2) preamp / amp for talkback 3) tally ptt circuit. I had perfect results from over 90 meters between videocamera & switching unit. Any body interested just ask.
    Raleigh, NC
    412
    I am interested . . . please send me the artwork.
    Matt Drabick
    I am interested as well. Sounds like a great setup!
    Jared Amos
    Nov 2007
    Cleveland
    28
    Me tooo!
    Please send me a copy.
    Chen Pan
    [email protected]
    Mar 2008
    CA
    42
    I am very interested.
    I also own a monster TriCaster Studio, 2 studio/field cameras (composite and svhs) and have been searching for the cabling solution. Please send any info, drawings or suggestions.
    Thank you
    Dec 2007
    Malta
    126
    Tally relay circuit - Panel G
    One of the most important factor in multicamera video filming is the TALLY. Attached is the circuit for the six cameras. Description. Tricaster outputs 5v from tally 3.5 socket on front. This is voltage divide by a 5k preset to out put 0.8v which is sent through one pair of twisted wire to camera end. This small voltage is fed to a transistor switch which switches a relay sending 12v to a 12 array LEDs. Later on I post photos of the box which is attached to the camera IDE battery fitting. This box has attached to it a 6inc TFT monitor, talk-back and tally. Hope I will find the time to do photograph them this weekend
    Attached Files Attached Files
    Dec 2007
    Malta
    126
    Panel G
    Note that I am using CAT5 cable to have easy visual track of wiring.
    Dec 2007
    Malta
    126
    Tally relay circuit at camera end
    this is the tally lamp switcher
    Dec 2007
    Malta
    126
    talkback circuit
    This circuit is common to all camera-persons and director. It consists of two parts - A) mic preamp to line level and B) headphones amp. It has a ptt which change over the function from listening to talking. This is a very important factor because it needs only a pair of twisted wire to send and receive.
    Dec 2007
    Malta
    126
    Studio camera Talk-back PTT box
    This small pcb is fitted in a very small plastic case high enough to house exactly the pcb push to make switch. When the ptm switch is pressed, the illuminated led shows camera man is on talk mode. At the same time, it switches on the talkback circuit relay thus connecting videographer's mic to director's speaker. When the ptm switch is release, the videographer's circuit returns to listening mode. Note that no matter how many talkback/cameramen are in the system, as long as only one at a time uses this talk function, everyone can hear.
    Dec 2007
    Malta
    126
    this is the Studio camera Talk-back PTT box
    Dec 2007
    Malta
    126
    Monitoring and output LCD
    The setup can be mounted on a unit measuring 30in wide. My outdoor system takes four field cameras. The production unit is made up of: 15" rackmount lcd, Four 4" LCD rackmount unit, the tricaster studio, 4 Kramer DAs, Tally & talkback circuits. Thats all! Assembled and easy to use as ABC.
    Mar 2004
    mizoram India
    46
    Hi Timecare, I am very interested on your work, I`ve been looking all over for this, BUT there is always an Error on these files Can you please send me or re- post it
    Timecare,
    This has to be the most generous sharing I've seen in quite a long time. Thank you immensely!!
