Thread: Movie within an animation
    Newbie Member kasigawa's Avatar
    Jan 2008
    Texas
    56
    How do i display a move/ animation within an animation?
    Like a TV screen playing a movie during an animation.
    I tried allying it as a texture, but it stays still; dose it need to be a certain type of file or do you have to do something to make it animate?
    Post-apocalyptic rakker16mm's Avatar
    Aug 2006
    Palo Alto California
    872
    Quote Originally Posted by kasigawa View Post
    You need to save your video that you want to use as a series of Still Frames. i.e. myVideo0001.tga myVideo0002.tga.....
    Then load up the Image Editor in Lightwave (button under Scene Editor)
    Load up the first image - myVideo0001.tga
    Find the dropdown menu item that says "STILL" Change it to "SEQUENCE".
    Now go to Surface Editor and apply to the surface.
    ANY and ALL textures can be made animated with this technique.
    please power off before disconnecting connecting connectors
    Mar 2006
    Wall Twp, NJ
    46
    Simply apply a movie file as you would an image map in your surface editor. The movie will get sucked in frame x frame as your scene animates. You just have to make sure that your imported movie and your scene are set at the same frame rate.
    Good luck.
    Aug 2006
    Eureka, CA
    6,962
    You can use AVIs and MOVs and more as a texture LW.
    shrox www.shrox.com
    Heavy Metal Landing
    Newbie Member Talc's Avatar
    Jan 2008
    Leicester
    93
    The only time you need a stills image sequence is if your going to render over a network as avi or movs need to be unpacked for the specific frame to render other wise everyrone else pritty much said it...
    Win7 64Bit
    Packard Bell IPowerX G5800
    i7 860
    8GB Ram
    Nvidia GTX 460
