Results 1 to 9 of 9
Thread: Trees blowing in the wind
    I am trying to create trees that blow in the wind. I know how to do it with endomorphs and textured displacements, but I was wondering about the wind emitter. I have never used it before. Can it blow trees around? If anyone can tell me of any tutorials about the wind emitter, I would appreshiate it.
    Evil Bastard Incorporated
    Head Office
    400
    Quote Originally Posted by skywalker113 View Post
    No, unfortunately. You see your model tree is just that... a static model with no flexibility built in. The wind emitter is a dynamic object and needs other dynamic objects to interact with, like particles, excellent for creating leaves being blown about or accurate smoke movement, but it won't bend a model around.
    This little chapter in history is over, ended, finito, no more, an ex chapter.
    Post-apocalyptic rakker16mm's Avatar
    Aug 2006
    Palo Alto California
    872
    You might try IK Booster with bone dynamics applied. About half way through the video he applies a wind emitter to move the bones. Just turn it upside down and it is a tree
    ftp://ftp.newtek.com/multimedia/movi...neDynamics.mov
    Jul 2008
    Nirvana
    9
    :o)
    You can use Cloth and wind dynamics. Here are a link :
    http://www.spinquad.com/forums/showthread.php?t=9309
    Thanks for the links
    Today I was messing around with textured displacements in order to make a pine tree leaves sway. I used the fractual noise texture. The tree looked nice, although it didn't look natural. Often, the upper part of the tree will sway more then the bottom, so I decided to try and use a gradient. I created a weight map, and made the bottom of the tree feel 20% of the weights effect. And the top of the tree 100% everything eles was in between and gradually increased, up the tree. I went to the displacement editor and added a gradient that used the weight map I created, but it didnt seem to work. I messed around with the settings, I thought I got somthing, but the weight map seemed to work in the opposite way, making the bottom sway the most. I tried reversing the gradient, and clicking invert layer, but it didn't do much.
    Aug 2006
    Hendersonville, NC
    6,962
    Do you mean like this? (the rar is a zipped file with an AVI of a tree test I did a while ago.) I did it with displacement and falloff.
    Attached Files Attached Files
    shrox www.shrox.com
    Heavy Metal Landing
    I'm not a squirrel! Mitja's Avatar
    Oct 2007
    Italy
    1,431
    Quote Originally Posted by shrox View Post
    Could you please explain better?
    I didnt even think of a falloff, thanks.
