Thread: Cycle between selected points
    Member hub73's Avatar
    Dec 2007
    France, Castelnaudary
    113
    Hi !
    Is there a shortcut to cycle between selected points in the case that they are exactly as the same location x,y,z ? (you know two points at the same position after use unweld ... and you must select only one to move it!)
    I know that you could use the 'info' button and deselect, but i'm searching a better way to do this quickly !
    Thanks lw gurus !
    (lw 9.3.1).
    I'm not sure if this will work for your specific situation, but you could try going into poly mode, select just one of the polys, and then use the drag tool.
    I'm not sure if I made that clear enough. Here's and example:
    Let's say you have a grid of polys two wide by five vertically. You want to unweld vertically down the middle, and seperate the points down that centerline.
    Select the points down the middle and unweld. Then, select just the strip of polys on the right, and using the drag tool, drag the points in the center away from their current position. Because the left polys aren't selected, the points on that side won't move.
    Eric
    Dec 2007
    113
    Yes ! Thanks Eric !
    Or you could selec your two points and then press 'i' to bring up the info panel. From the info panel you can select the points one at a time, you can also see things like their exact coordinates and any maps that are associated with them.
    -Joshua Jorgensen
