Thread: divx
    Mar 2007
    glasgow
    1
    divx
    using lw 9.3 on a vista 64 machine, installed the new divx 6.8 but under the render options it is not showing the divx codec ??, but when i installed on my vista 32 laptop lightwave picked up straight away..
    is this a 64 bit issue ? and is there a workaround,
    Stuttgart, Germany
    13,569
    DiVX is 32bit only, and can thus only be used from 32bit apps, not from 64-bit apps.
    Cheers,
    Mike
    Super Member Cougar12dk's Avatar
    Dec 2003
    Denmark
    1,078
    Blog Entries
    1
    I've contacted DivX people about this problem and it apperas they (divx and NT) are working on a solution to this.
    Until then i render to image sequence in 64bit and render the animation using the image seq. in 32bit.
    Core i7-3770K 3.5Ghz, @ 4.181GHz
    16GB DDR3 PC3-12800 - 1600Mhz
    Gigabyte GeForce GTX 1060 WindForce OC 6GB GDDR5 PCIe-3.0 x16
    Windows 10 Professional 64bit
