Thread: Problem Smoothing a Model
    Anyone know what is preventing this polygon from remaining smooth when it it taken into Layout? I've attached shots of how the problem area appears in Wireshade and Smoothshade mode in Modeler (does not appear) and how it appears on the stage in Layout and in a rendered frame from Layout (this is where the problem appears).
    Thanks.
    -Bill
ID:	59077   Click image for larger version.
ID:	59078   Click image for larger version.
ID:	59079   Click image for larger version.
    Registered User Kuzey's Avatar
    Melbourne
    5,262
    It seems that section might be named something different from it's neighbor and it's smoothing property is unchecked in the surface editor.
    Kuzey
    Thanks Kuzey, you nailed the problem.
    I had been simplifying the polygons in that area and accidentally used another surface, with the same color.
    -Bill
