Results 1 to 2 of 2
Thread: polys showing in render
    May 2008
    USA
    4
    I'm surface baking and polys are showing in parts of the render, like this:
    surface baking example
    This image was created using the surface baker renderer. This is all one surface. Double-sided polys is not checked in the surface editor.
    Any clue how I might fix this?
    Thanks,
    Amy
    In modeler is the UV map set to sub patch interpolation? You can check that and change it in the map panel f8. I assume it is a subpatch object and if so the UV should be subpatched. Something worth checking.
