Thread: PolyFlipping
    Creator of the Strange Skinner3D's Avatar
    Feb 2006
    Brocton NY
    902
    PolyFlipping
    How do I get all of my polygons to face the same direction? I have a model that has about half of my polygons facing one way and the other half facing the other way, all mixed together
    Is there an average function or something?
    Every time I think about Marvin the Paranoid Android, I realize just how good my life is.
    My site http://www.freewebs.com/skinner3d
    There is the Align tool in the Detail Tab. Sometimes it does not get everything. I have even heard of some 3P plugins that work better but this one should get you most of the way there if not completely depending on the situation.
    Feb 2006
    Brocton NY
    902
    yep I knew I missing the obvious. It worked great, but now I realize I also have literal double sided polygons, how does one fix those?
    I have no clue how my mesh go so messed up
    Feb 2006
    Brocton NY
    902
    Okay I have real problems. They are not only double sided, but tripled sided as well. I think my only method is manual delete and destroy, but if there is another way I am open to suggestions.
    Javis Jones: Night Crew geothefaust's Avatar
    Aug 2005
    Oregon Territory
    4,214
    There is another tool that will solve that problem for you, if I'm understanding you correctly.
    It's called 'Unify Polys', and it's under Detail>Polygons
    Hope this helps!
    Feb 2006
    Brocton NY
    902
    Oooh now you tell me. . . after I spent the better part of several hours doing it by hand last night
    Well much thanks to you both. Definately going to file the above two things away for future reference.
    Two things you'll never forget.
