Thread: Rounder Problems - Please help
    Dec 2007
    Australia
    18
    Hi... I'm back once again with what must be a simple issue for most LW users but I cannot get it to work for me. I am trying to round off the top edges of this hollow circle. Essentially I am trying to get a nice rounded off surface for the top of the shape. This is what I have done. Selected one edge and then Selected Loop. The full circle was correctly selected. Fine so far. But when I tried to use Rounder it comes up with this error message (attached). I have also attached the object file which is causing me the problems. Appreciate any help..Thanks heaps.
Name:	Rounder problem screen dump.jpg
    Attached Files Attached Files
    Mar 2004
    Derbyshire, UK
    3,128
    Dude - before you do anything merge points, you have spare in there, then get rid of all the 2-point polys in your object. It'll work then (though for some reason I can't get Select Loop working with edges)
    Here's a small tutorial I put together on the Lightwiki.
