Results 1 to 14 of 14
Thread: Glass problems...
    Apr 2008
    United States
    48
    Question Glass problems...
    I followed William's tutorial (here: http://www.newtek.com/forums/showthread.php?t=78198) to the letter, but I just can't seem to get a good glass effect. Here's what I came up with after following his lead....
    *big image alert*
    http://img131.imageshack.us/img131/8867/picture2fm6.png
    This doesn't look much like glass at all. I do have all the important ray trace options enabled.
    I've also tried playing around with Absorption and RI - without much luck. What could I be missing?
    Any suggestions?
    Thanks,
    MS
    Faith is not the opposite of intelligence. The lack of faith is the lack of intelligence, for it is impossible to know everything.:thumbsup:
    Macs FTW:yoda:
    Dec 2006
    Philadelphia, PA
    5,738
    You have reflection and refraction enabled? just checking...
    Apr 2008
    United States
    48
    Yep
    Correct. Both are enabled.
    Macs FTW:yoda:
    Old Dog Learns New Tricks RudySchneider's Avatar
    Jan 2006
    Lincoln, CA
    1,307
    Don't forget that there are separate Render Global as well as Camera Properties. If you're simply changing the Global Properties, but haven't checked "Use Global" in the Camera Properties dialog box, you'll be disappointed.
    There are no problems, only opportunities...
    Apr 2008
    United States
    48
    Sadly, that didn't help it. Although I don't know why.
    Macs FTW:yoda:
    3D & FX Animations DAMAKERS's Avatar
    Venezuela
    114
    have u turn on the nodes in the surface pannel?
    also could u put something to be refletcted so can see the glass behavior.
    maybe u know all this, but trying to help
    Dec 2006
    Philadelphia, PA
    5,738
    The easiest thing is to probably zip up your model and scene and post it here so we can take a look....
    Apr 2008
    United States
    48
    Files
    Alright. Here are my files, LWS and LWO.
    Messing with Absorption has some weird effects. If I set it to 1.0 or higher, the glass is invisible.
    Also, the "glass" material is named "Cup" in my scene.
    This was done on an Intel Macbook Pro with LW 9.3.1 Mac32.
    Thanks for any suggestions, guys. I do appreciate it.
    MS
    Attached Files Attached Files
    Macs FTW:yoda:
    Jan 2006
    Lincoln, CA
    1,307
    You've got a couple things going on here, MSwengel...
    1. Your object is HUGE! When you model, try to scale your objects to real-world dimensions. The primary reason for this is that the lighting and camera in Layout are based on real-world optics.
    2. Your glass is quite thick. Hence, it will naturally absorb more light.
    3. Try not to use 100% diffuse settings for your materials. something on the order of 60-to-70% is more realistic. Learn to rely more on your lighting (which I also bumped up to 100% for BOTH lights) to set the mood..
    I did a quick reduce of your model to 9% of what was, repositioned the camera, and here's a simple render:
    Jan 2006
    Lincoln, CA
    1,307
    BTW, I set the absorbtion to 20 (percent), and th refractive index to 1.5.
    Apr 2008
    United States
    48
    Ahhhh! Now that makes sense. It was absorbing too much light because of its size - in layman's terms. Thanks!
    Macs FTW:yoda:
    Apr 2008
    United States
    48
    Quote Originally Posted by RudySchneider View Post
    Could you post your scene file? I resized the object (in Layout) and readjusted the camera and values - without much luck.
    I've attached the altered file. It's "resized.lws."
    Macs FTW:yoda:
    Jan 2006
    Lincoln, CA
    1,307
    I didn't resize the objects is Layout. I resized them in Modeler, where it's supposed to be re-sized. I didn't save the Layout file, but here's the Object file. BTW, I also centered everything, and placed your backdrop on the X-Z plane, just out of habit.
    Apr 2008
    United States
    48
    Aha! I see! Thank you, RudySchneider!
    Note to self: resize in Modeler...
    Thanks again,
    MS
    Macs FTW:yoda:
