Results 1 to 9 of 9
Thread: .3DS export suggestions...
    Hello,
    I am currently working in a forensic software which deals in .3DS for it's objects.
    I have some viable .LWO objects which would be useful in the project, too.
    Any suggestions as to how to reduce the .LWO for .3DS parameters.?.
    I'm not too familiar with .3DS other than it seems to be a low polygonal count.
    Just merge points, reduce polys, QUEM loss?
    Any methods?
    Thanks!
    Ty
    VT5 & LW 11.6 Abuser
    Core i7
    GeForce GT 540M
    Lots of RAM
    Certified CRT Fossil User
    Dec 2006
    Philadelphia, PA
    5,738
    I don't think the .3ds file is low poly. But I do think that it needs tris only. So you might want to triple your LW object first before export, or put in the tris where you feel they will go best.
    That being said if you're looking to lower the poly count of the models quem loss might be a good way to go...
    Jeffry,
    Your're right- a combo of all of the above.
    And LW was telling me there was a 65K polygon limit as an error when I tried to export over that limit.
    All set, thanks for your help, keep the tutorials coming!
    Ty
    Core i7
    GeForce GT 540M
    Lots of RAM
    Dec 2006
    Philadelphia, PA
    5,738
    Thanks Ty...
    Glad you got it working... I was not aware of a poly limit with 3ds exporting out of LW, so thanks for that bit of info!
    Apr 2005
    Regina, Canada
    296
    Only triangles can be written to a 3DS file.
    Texture names follow the old 8.3 limit. 8 characters for the name and 3 for the file extension. Even though the file format will allow longer names, 3DS Max follows the original file spec and will only read the 8.3 names.
    There is a 65K limit per mesh stored to the 3DS file. Multiple meshes can be written to the file and this is done by third party file converters.
    Layer and material names have a 10 character maximum limit.
    Wayne
    Dec 2006
    Philadelphia, PA
    5,738
    ^that's great info to know on the file format MM!
    And when it comes to beautiful conversions from LW, may I suggest Accutrans3D, a very affordable and effective option ..
    At least this is the way I always do it.
    For your info, if you want to go for some reason in the opposite direction and bring triangulated meshes into LW, and turning three sided faces into quads in LW, look for MergeTrigonsX on Flay.com
    Model: MacBook Pro 10.6.4 - 2.66 GHz - 4GB - NVD GF GT 330M
    Render: Win7 64 - Core 2 Quad Q9550 2.83GHz - 8GB
    Apr 2005
    Regina, Canada
    296
    Quote Originally Posted by archijam View Post
    If you are using AccuTrans, you can use the "Tools -> Triangles to Quads" menu command to turn triangles into quads. Use the "Prefs -> Options" menu command to open a dialog box to change two settings that affect the creation of quads.
    Wayne
    Thanks Wayne .. never saw that functionality! Actually I use it quite often, but when I do, I always find it's been updated in the meantime :P .. makes me feel very unproductive ..
