Results 1 to 15 of 15
Thread: sunrise
    A lot of nothing to say. 99sproth's Avatar
    Bournemouth, England
    261
    sunrise
    Heres my first post on these forums, im practically a newbie so I'd like any constructive critiscism!
    The image took about 20 minutes to render and has 30mb of texture infomation.
    What do you think?
    simo
    Simulations engineer, technical director.
    ________________________
    [email protected]
    www.machinestudios.co.uk
    Delusions of Adequacy Mebek's Avatar
    Trapped behind the Zion curtain
    183
    From a purely artistic point of view, I think it looks cool. That lens flare might give me a headache if I look at it too long though.
    From a realistic standpoint, I'd like to know where the light is coming from, if the sun is behind the planet? I'd also tone the flare down some - try not to use every setting in the Lens Flares panel.
    But like I said, I think it looks cool. Keep it up!
    --Mebek
    wow, I'd tone down that flare.
    those must be some textures!
    Banned Epita's Avatar
    Not where you are
    379
    bloom
    Thats cool, maby OTT. A great effect is to use Bloom to make the sun sort of spread out over the atmosphere makes for great movies...
    Epita
    261
    Yeah, i do admit the flare was total overkill, it didn't seem so umm... explosive in open gl.
    I used 6 texture maps on two objects.
    on the earth a colour map and a bump map
    and on the atmosphere a transparacy map and a colour map.
    If anyone wants the textures or model I'll be happy to share.
    simo
    [email protected]
    Registered User Meaty's Avatar
    Arlington, VA
    458
    It looks good as a stylized render... one flaw is that there is essentially zero ambient light in space... so if the sun is coming over that side of Earth, than almost the entire planet would not be visible.
    Chris Moschella
    do you have a version w/o the lens flare that you can post? The planet seems to be pretty cool, but it'd be easier to comment on if it were more visible.
    Digital Delight for Analog People
    www.DereksDigital.com
    Newbie Member Zombat's Avatar
    Conneticut
    91
    Always use lens flares in moderation. Many times they are unnecessary, as well as the circles and red ring. Sure, they give the image a photographic look to them, But I like to get rid of all the camera acessories, so as to make it seem like you were looking at the scene from say, out a window.
    Also, it seems as if you've changed the surface of the planet so it has an smoothed edge - very un-planet-like, if that exists, take if off.
    The sun could be a lot better. Replace the blaring light with a high-intensity yellow-orange sun, and place it a little further off from the planet. Put a point light at the sun's core with the same color as the glow, give it a lens flare, but with nothing other than random streaks. Keep the flare intensity down enough to make it look as the sun is glowing, but not BLARING.
    Remove all other lights in the scene, and the planet would look a little more realistic.
    Neat otherwise.
    [url=http://www.roosteredge.com/~zombat/nebula/tute.html]Zombat[/url]
    261
    Ok here it is without all the cool effects, bad effects, blurs, flares etc...
    [email protected]
    Arlington, VA
    458
    if the angle in the second pic shows where the sun is, then the edges of the earth would be much more prominent...
    here is a link to a cool earth tutorial, it is a little dated, LW 5.6, but it still works.
    http://personal.southern.edu/~dascot...nasa-earth.htm
    and here is a link to a nasa site that has the most bitchin' high resolution eathmaps i have ever seen. 24000 pixels wide. dont even try to look at it in openGL or lightwave will crash. infact, i had to dumb it down to a 15000 pixel wide jpg for it to render without crashing, still an amazing image. you can use these maps to replace the maps that are available at that earth tutorial site. you'll have to email the Nasa people for the ftp info to download the biggest one, i did, and they emailed me back ftp info within the week. Good luck!
    edit: whoops, forgot the second link http://earthobservatory.nasa.gov/Newsroom/BlueMarble/
    Chris Moschella
    261
    Wow cool!
    cheers!!
    [email protected]
    Not where you are
    379
    Question
    wow, those pics are amazing. But my LW crashes whenever one or two textures are put in it, any one know about this???
    Epita
    Arlington, VA
    458
    epita, turn off OpenGL textures, should do the trick
    Chris Moschella
    183
    from a realistic standpoint, you would never see that much bump in the Earth's surface from this far away -- it would look as smooth as a ping-pong ball.
    Is it just my eyes, or does Africa look really stretched out?
    The lighting on the Earth would also be much more general, looking evenly lit across the daytime side and a fairly fast falloff into the nighttime side.
    but artistically, I actually like the bump map, especially there in the Sahara Desert and farther south. Looks like illustrations from a Rand McNally atlas or something.
    --Mebek
    261
    Well i was going for an artistic look, i dropped geography for history!!
    As for the stretched africa i have some amazing news!!
    There are two types of maps!! I can't possibly explain in under 2000 words but people are campaigning because the current map system is unfair and makes some countries look smaller and therefore less importent(?!).
    how or why? - i frankly don't care
    I seem to be using the new type system.
    Simo
    [email protected]
