Thread: help spinning objects
    Can anyone help me? I need to get the wheels on a car i made to spin any ideas?
    "can't you hear those cavalry drums?
    hijacking your equilibrium
    midnight hags in the mausoleum
    where the pixilated doctors moan"
    Fórum áss clówn Hopper's Avatar
    Jan 2005
    Austin
    3,393
    Exactly what the doctor ordered...
    Dr. Wheel
    Enjoy .. courtesy of our own William Vaughan
    Note: If you simply need to make a wheel turn and that's it... make sure the wheel is a seperate object than the rest of your model, set the pivot point, use the graph editor and the rotation channel ... (hint: do a little research.. I'd rather be an enabler than simply give you the easiest answer .. You'll learn a whole lot more that way).
    Playing guitar is an endless process of running out of fingers.
    WOW, the was exactly what i was looking for thank you so much
