Thread: Animation: Gala 2007
    Member precedia's Avatar
    Mar 2006
    Freedom, California
    212
    Rendered in LightWave 9.x with Vue 6 xStream on a Mac.
    See my post here for the full animation.
    Daniel
    Heffalump
    Away
    3,897
    There's something about the lighting that I'm not keen on - an overlit, plastic-like feel to the image. It might be intended, though.
    The shadow flow is also...odd and overly sharp. Shadow maps or the spinning light trick might help.
    Inactive.
    Mar 2006
    Freedom, California
    212
    Phil, I agree with you. I will try your spinning light trick in a future animation to see how it performs. In this case there is one spotlight for the scene, and rather artificial as you note.
    I ran into 2 problems with this animation sequence: 1) when I darkened the scene to have more night-time ambiance, then projected on my rear-projection outdoor screen, it was too dark to see and the test subjects complained, so I brightened the entire scene (artificially, which you immediately noticed), and 2) render time.
    For renders I had to stay away from area lights because of render time (although they give great soft shadows), and minimize not only the number of lights but anti-aliasing. This frame suffers AA issues, with only PLD-2 used (ugh! way too low). Anything more in the AA department and per-frame render times pushed the animation sequence render > 25 days.
    I had > 14,400 frames to render, so it was a real struggle given a limited render farm; well, no render farm really, just 2 machines and the month of September.
    But I never did perform the spinning light test to see if the per-frame render times are reasonable. Thanks for that tip.
    It would be interesting to run a test just on this single frame with either spinning lights or an area light.
    Thanks for the feedback.
