Thread: rendering the edges
    rendering the edges
    is it possible to render only the edges of a model? And can you also control the thickness of the edge? Thanks.
    I should add that I've tried the wireframe render but it looks too heavy. Is it possible to control the thickness of the wireframe render? Is this a question for the math guys at Newtek?
    you should be able to adjust the thickness... Object properties/Edges and then adjust the pixel dimensions of the particular edges you want to show up.
    ___________________________
    Matthew Bohan Illustration
    http://home.comcast.net/~bohanart/
    May 2005
    Wisconsi USA
    134
    William Vaughan has a video tutorial , I think called outlines .
    http://www.newtek.com/forums/showthread.php?t=77002
    Quote Originally Posted by mattyb
    Cool. To get the full effect I just turned the transparency up to 100%. Thanks.
    Quote Originally Posted by markschum
    yes. thanks. that is also a big help. I have to be careful on his web site. I start watching his movies and never get any work done.
