Thread: Modeler sketch color
    Super Member Boris Goreta's Avatar
    Zagreb, Croatia
    1,347
    Is it possible to to tell Modeler to use sketch color that is allready applied to the surronding polygons once it generates new ones. It allways uses default sketch color for newly generated polygons. For instance, if I use knife tool I want newly generated polys to inherit the sketch color from the original object.
    The rule is: New geometry gets whatever sketch color is selected under Detail--Polygons--Sketch Color. I don't know if that's helpful to you or not.
    Super Member Roly's Avatar
    Mar 2006
    Florida
    329
    Quote Originally Posted by Giacomo99
    No, it always use Default Sketch Color selected under the Display Options.
    My specs for now:
    Pentium IV 3.4Ghz, 2GB of RAM
    GeForce GTS 250 512 MB Driver Ver. 260.99Windows XP Pro ( 32 bit ) SP3
    Quote Originally Posted by bgoreta1
    That would be a cool feature. Why not sublit it as a feature request?
    Zagreb, Croatia
    1,347
    I did already.
    Good. I'd like to see it happen.
