Thread: Detect displaced points
    Hello,
    I've got an object displaced with an plane effector. I would like to surface it differently in the displaced zone and in the non displaced zone.
    I'm looking a way in the surface node editor to detect if a point ( spot? ) is displaced or not...
    any clues?
    regards,
    eben
    ANIMEA|CG animation
    lwf.fr|French LightWave Forum | Forum LightWave francophone
    Base this on a gradient from pivot, if you are displacing into the positive and negagive, or from some objects pivot that is bisecting your non- and displaced areas.
    Gradients seeking out your displaced zones, as it were, are the better bet.
    thanks for your answer,but...
    sorry, i dont understand very well your explanation...( i'm french ). Can you be more specific ?
    regards,
    eben
    ANIMEA|CG animation
