Results 1 to 2 of 2
Thread: LW 9.3.1 Output Format numbering is incompatible with previous versions.
    NewTek changed the numbering order of the output format for LW9.3.1.
    They added new formats and changed the number order that makes it
    incompatible with previous LW versions and it may cause image output
    problems when people try to render scenes between this version and
    older ones. This affects the "OutputFilenameFormat" setting stored in
    the LW scene.
    Here is a list of the affected output formats:
    < LW9.3 LW9.3.1
    "Name_001" 4 8
    "Name_001.xxx" 5 9
    "Name_0001" 6 10
    "Name_0001.xxx" 7 11
    If the user saves one of these output formats with LW9.3, and then
    opens the scene in LW9.3.1 it will be a different format, and
    vice-versa. Saving a scene with LW9.3.1, and opening the scene in
    LW9.3 will always default to "Name_0001.xxx" since the number order in
    the previous versions ended at "7".
    NewTek should put the old numbering order back in the next release,
    and assign new formats with unassigned values.
    I reported this as a bug in LW9.3.1 and the latest Betas
    What do I know? JBT27's Avatar
    Jan 2004
    Chester, England
    2,250
    Yes.....
    For anyone 'suffering' with BNR over this, check this thread:
    http://www.newtek.com/forums/showthread.php?t=77983
    Julian.
    LW 2015.3 Win 10 Pro 64bit
    http://www.take27.co.uk
