Results 1 to 8 of 8
Thread: Bump map to normal map...
    May the sauce be with you starbase1's Avatar
    London, UK
    5,571
    Hi All,
    I have a bump map texture done in the usual layered way. I'd like to replace it with a (node based) normal map with the same tiling and position etc.
    Given the much better effect of a normal compared to a bump this must be a very common task - is there an easy way to do this?
    Thanks,
    Nick
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    May 2006
    France
    3,922
    You could copy all bump layers,
    pasting them in a Layer Bump node,
    and there's a Bump To Normal node
    in DP Kit.
    Denis.
    London, UK
    5,571
    Quote Originally Posted by dpont
    in DP Kit.
    Denis.
    DP Kit?
    Heir to the Throne RedBull's Avatar
    Apr 2005
    Underground
    1,608
    Quote Originally Posted by starbase1
    DP Kit?
    http://pagesperso-orange.fr/dpont/pl...l_Nodes_2.html
    London, UK
    5,571
    Ah thanks, I'll take a look. In the mean time, and trying to do it manually, (not a bad thing to know how to do!), I'm getting a bit lost.
    The bump map I am using is cylindrically mapped, and I can't see an equivalent to the 'width wrap' parameter in the layered approach.
    Any clues anyone please?
    Nick
    Apr 2005
    Underground
    1,608
    Nick
    Width Wrap and the panel itself is identical in the "layered" nodes.
    If you read Dponts post he mentions to copy your layers to a layered bump node.
    as opposed to the standard image node.
    London, UK
    5,571
    Quote Originally Posted by RedBull
    Ah, thanks - I was using an image node.
    Nick
    Dec 2003
    Portugal
    1,819
    I guess you can do that with this soft
    http://www.crazybump.com/
    or this:
    http://www.xnormal.net/Faq.aspx
    from the page:
    Q: What is xNormal?
    A: xNormal is an application to generate normal / ambient occlusion / parallax displacement maps. It can also project the texture of the highpoly model into the lowpoly mesh ( complete texture transfer, even with different topologies ). Includes too an interactive 3D viewer with multiple mesh and textures format support, shaders and realtime shadowing / glow effect.
    To finish, comes with some useful tools like height map - normal map - cavity map - occlusion - tangent/object space tools.
