Results 1 to 12 of 12
Thread: Object File Corruption
    Einstein Status. firstsingle's Avatar
    Atlanta, by way of Los Angeles, CA
    711
    Unhappy Object File Corruption
    Hey guys. How do you know your obj file has been corrupted?
    Had a scene. Layout crashed. Now my obj file wont load.
    reads; Error reading file.
    Is this the dreaded message?
    LorenzoS
    My favorite artist is God.
    In the beginning God created the Heaven and the earth.
    Macbook Pro4,1 - 10.6.8 - 2gb Ram - 512mb VRAM
    Running at 29.97 fps Titus's Avatar
    Mexico City
    2,839
    There's a chance your model got corrupted with the crash. LW stores a hidden copy of your model somewhere on the hard disk, I don't have the location right now.
    711
    Thanks Titus. When you find out please share that Info.
    LorenzoS
    Try opening with Accutrans3D .. ? Worth a shot.
    j.
    Model: MacBook Pro 10.6.4 - 2.66 GHz - 4GB - NVD GF GT 330M
    Render: Win7 64 - Core 2 Quad Q9550 2.83GHz - 8GB
    Pancakes! IMI's Avatar
    Apr 2007
    Right Here
    7,124
    Depends on what version of Windows. Should be in Documents and Settings/Users/Application Data/Temp/lwhub, IIRC, on Win 2000 and XP. Something like that - I think, in a folder that's set to Hidden, by default. You'd have to have Hub enabled and running, with automatic save enabled, though (which it is, by default). Mac, I don't know, and Vista.... I can't find anything in Vista.
    no comment
    711
    archijam.
    Trying Accutrans3D, Thanks.
    IMI.
    I think my problem may be that I didn't have auto save enabled.
    I'm on a mac. I can't find a Cleanup at Startup folder as suggested in my
    1001 LW 3D8 Tips & Tricks book.
    LorenzoS
    Apr 2007
    Right Here
    7,124
    Bummer.
    If Accutrans doesn't work, try 3d Exploration, by Right Hemisphere. I think the demo allows saves with no restrictions.
    Cool signature line, by the way.
    no comment
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,663
    Blog Entries
    1
    search for folder "LWHUB" , minus the quotes
    C:\Documents and Settings\Administrator\Local Settings\Temp\lwhub
    is were there are [PC], i don't were on a mac
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
    Apr 2007
    Right Here
    7,124
    Yeah, that's right zapper, thanks.
    And I meant to say Deep Exploration. Six years after it got bought out and had its name changed, and I'm still calling it 3D Exploration.
    no comment
    711
    Hey Thanks for all your help guys.
    Gonna try all these tips.
    I'll let you know what happens.
    LorenzoS
    Good luck. And enable autosave and keep your index finger on the "s" key at all times.
    I am on a Mac as well, so be sure and let me know if you find out where the temp files are.
    visual effect/mograph artist
    Cinema 4D | Lightwave v9.6 | modo 401 | Maestro 2 | Kray 1.7
    MacBook Pro C2D 3 GB
    Pessac
    5,038
    The temp files are hidden away and need Terminal to find them on a Mac. Richard Brak wrote me an Applescript to extract files from the hidden Hub folder, but it may not help since the hub autosave files are deleted by OS X every time the machine is restarted. Here's what Richard had to say:
    "Attached is a (stuffed) applescript with creates an alias to the
    directory the Hub uses to store the hub files. The auto saved files are
    stored in the lwhub directory (as far as I can tell). To use the
    Applescript the users should first unstuff it to create the script
    application called "makeAutosaveAlias". The user need only double click
    the script and it will then prompt the user for a folder in which the
    alias will be created.
    It is a very simple script hence not what I would call "bullet proof"
    however, it should be perfectly safe to use."
    The Applescript is compressed using Stuffit and then embedded in a zip file to allow it to be uploaded to the forum.
    B
    Attached Files Attached Files
    LightWave 3D Trial Edition
