Results 1 to 10 of 10
Thread: Modeler Numeric Panel Rotation bug? (all versions)
    gold plated 3D Chrusion's Avatar
    Chatannooga, TN
    1,080
    OK, this thing has been bugging me like forever in Modeler and it seems it's been this way ever since there's been a numeric panel.
    Do this...
    Select an object (points or polys, doesn't matter)
    Pick Rotate tool
    Mouse drag rotate the object any amount in any view port.
    Drop the tool
    Undo the rotation
    Pick Rotate tool again
    Open Numeric Panel (it has remembered the previous rotation angle, center, and axis)
    Click the Apply button
    What happens?
    Yep... Rotation occurs in the "negative" direction!!
    WHY?
    Modeler must be flipping the rotation axis 180 deg internally or something. Does NT need to fix this?
    Dean A. Scott, mfa
    Senior 3D Animator and Graphic Design Illustrator, @ Astec, Inc.
    Owner / Lead Artist @ chrusion | FX
    Guru Meditation Sande's Avatar
    Los Angeles, Helsinki
    646
    Not in any viewport. That does happen when you for example rotate using mouse from top viewport - but if you are using bottom viewport mode it works correctly. It also works if you have first rotated the object without mouse using numeric panel.
    That is one of LightWave's "undocumented features" I guess... I'm nowadays so used to it, that I don't even notice it.
    Riding the LightWave with Commodore 64, MOS [email protected],985MHz and 64kB's of RAM and Videopac G7000, Intel [email protected] MHz with 192 bytes of RAM
    Animation Monkey iconoclasty's Avatar
    Jan 2006
    Michigan
    926
    How the #$% haven't I noticed that before!
    Sande's right though. Top viewport does it, but not Bottom. Front Does, back does not. Right does, Left does not. I can kind of see why, but that is strange.
    Friends come and go, but enemies accumulate.
    I have noticed this but had not made note of which windows. Thanks for testing it.
    That makes sense now because simply there is only one negative direction and one positive direction. It is not a bug. There is no reason that the negative and positive would change from viewport to viewport; certainly not any more than (-) or (+) on the X would be any different in the front or back view in so far as the numeric requester is concerned.
    Chatannooga, TN
    1,080
    AH! So it IS an axis "look direction" or "polarity" issue and numeric is basically missing this vital piece of information!
    Then wouldn't it be advisable to have the numeric panel remember this key property when it remembers the other values so that when it is reinvoked, the rotation is repeated on the same axis "polarity" so you get the exact same results as with the mouse? Well, of course! Did I just sense Chuck whispering to the dev team to "make it so?" hehe
    I bet this affects all the other tools that work on this 'axis look direction/polarity'. Hmmm...
    Dean A. Scott, mfa
    Professional ConfUser VoltisArt's Avatar
    Jan 2004
    Los Angeles area
    22
    Would be more sensible for all the numeric inputs to be absolute instead of relative. Let the mouse work exactly like it needs to, but show the numbers relative to the universal origin, not the viewport. This wouldn't change anything as far as starting off with numeric input...it would only change the numbers displayed when dragging with the mouse in those "backwards" viewports.
    Hint hint, v10 dev team.
    twisted mixer of pixels KevinL's Avatar
    Oct 2003
    Colorado
    440
    Hint, hint v9.5 dev. team
    There is something far greater.
    Dec 2003
    Portugal
    1,819
    yep I've noticed that since ever...ah well, it's one of those things that after a while you get used to...but it should be corrected.
    Sep 2005
    Earth
    3,121
    I didn't notice this until you mentioned it. Funny. I've been using lightwave since version 5.4 on the amiga (I was 8 back then(or something close))
    Yeah, it is just a display issue in the Numeric panel that is consistent with the mouse movement rather than the origin. Never really bothered me too much.
