Thread: Having Issues adding points
    Unknown Cavern
    930
    I have been digging into the spikey sample in the SDK. It works fine until I erase some code, then nothing happens. Here is the Section I am referring to:
    static EDError Subdivide ( SpikeyData *dat, const EDPolygonInfo *pi )
    MeshEditOp *op = dat->op;
    EDStateRef s = op->state;
    EDPointInfo *vi;
    double cen[3], norm[3], d;
    LWPntID cg;
    LWPntID vl[3];
    int i;
    if (!( (pi->flags & EDDF_SELECT) && pi->numPnts >= 3 &&
    (pi->typeFlags & LWGPTF_SURFACE) ))
    return EDERR_NONE;
    * Count this polygon in the aggregate for the monitor. The
    * step function returns True if the user has requested an abort,
    * which we can propogate by returning the appropriate code.
    if (dat->mon && (*dat->mon->step) (dat->mon->data, 1))
    return EDERR_USERABORT;
    * Compute the CG of the polygon vertices as `cen.'
    cen[0] = cen[1] = cen[2] = 0.0;
    for (i = 0; i < pi->numPnts; i++) {
    vi = (*op->pointInfo) (s, pi->points[i]);
    if (!vi)
    return EDERR_NOMEMORY;
    cen[0] += vi->position[0];
    cen[1] += vi->position[1];
    cen[2] += vi->position[2];
    cen[0] = cen[0] / pi->numPnts;
    cen[1] = cen[1] / pi->numPnts;
    cen[2] = cen[2] / pi->numPnts;
    * Compute the average distance from a polygon vertex to
    * the center point.
    d = 0.0;
    if (!vi)
    d += Dist3D (vi->position, cen);
    d = d / pi->numPnts;
    * Translate the center point out of the polygon's plane by this
    * average distance times the spikeyness factor. This translation
    * can only be done if the polygon has a valid normal.
    d *= dat->spike;
    if (d && (*op->polyNormal) (op->state, pi->pol, norm)) {
    cen[0] += norm[0] * d;
    cen[1] += norm[1] * d;
    cen[2] += norm[2] * d;
    * Create a new point at the offset center position. VMAP vectors
    * will be an average of the values at the polygon vertices.
    cg = (*op->addIPnt) (s, cen, pi->numPnts, pi->points, NULL);
    if (!cg)
    * Loop over points in the polygon and create new triangles
    * from each pair to the center. We use `addPoly' rather than
    * `addTri' since we want to preserve the original polygon
    * tags and sidedness. Note the "modulo numPnts" to make
    * the point index wrap around the end of the point array.
    vl[0] = cg;
    vl[1] = pi->points[i];
    vl[2] = pi->points[(i + 1) % pi->numPnts];
    if (!(*op->addPoly) (s, pi->type, pi->pol, NULL, 3, vl))
    * Delete the orginal and we're done.
    return ((*op->remPoly) (op->state, pi->pol));
    All I did was removed:
    vl[0] = cg;
    Recompiled the plug in and it Ran BUT I GOT NO POINTS!!!!!!!
    WTF?! I spent 5 hours and am beating my head against the screen now. I even changed:
    to :
    cg = (*op->addPoint) (s, cen);
    And got nothing as well. So I am lost now, I can not figure out how to put a stupid little point into Modeler!!!
    Here is ALL the code:
    * SPIKEY.C -- Make a polygonal object spikey while subdividing
    * Copyright 1999, NewTek, Inc.
    * written by Stuart Ferguson
    * last revision 30/99
    #include "spikey.h"
    #include <lwserver.h>
    * Interface globals.
    DynaMonitorFuncs *globFun_mon = NULL;
    LWXPanelFuncs *globFun_pan = NULL;
    * Local information packet. This includes the mesh edit context, monitor,
    * and polygon count. Also holds the variable spike factor.
    typedef struct st_SpikeyData {
    MeshEditOp *op;
    LWMonitor *mon;
    unsigned int count;
    double spike;
    } SpikeyData;
    * Utility to return the distance between two 3D points.
    static double Dist3D ( double v1[3], double v2[3])
    double d, z;
    int i;
    d = 0.0;
    for (i = 0; i < 3; i++) {
    z = v1[i] - v2[i];
    d += z * z;
    return sqrt (d);
    * This is called for all the polygons as a preliminary pass to count the
    * affected ones. Polygons are only processed if they are faces, they are
    * selected and they have at least three vertices.
    static EDError CountPols ( SpikeyData *dat, const EDPolygonInfo *pi )
    if ((pi->flags & EDDF_SELECT) && pi->numPnts >= 3 &&
    (pi->typeFlags & LWGPTF_SURFACE))
    dat->count ++;
    return EDERR_NONE;
    * This is called for all the polygons to delete them and replace them with
    * triangles around a centeral displaced point. The check for which ones
    * to process and which to skip is the same as above.
    EDPointInfo *vi;
    LWPntID cg;
    LWPntID vl[3];
    int i;
    return EDERR_NONE;
    if (!vi)
    * the center point.
    d = 0.0;
    if (!vi)
    d *= dat->spike;
    if (!cg)
    vl[0] = cg;
    * Perform a spikey subdivide given a MeshEdit context and a spike factor.
    * This returns the error code, if any.
    int Spikey ( MeshEditOp *op, double factor )
    SpikeyData dat;
    EDError err;
    dat.op = op;
    dat.spike = factor;
    dat.count = 0;
    err = (*op->polyScan) (op->state, CountPols, &dat, OPLYR_PRIMARY);
    if (err) {
    (*op->done) (op->state, err, 0);
    return err;
    * Start the monitor. If we can create a monitor, initialize it
    * with the polygon count.
    dat.mon = (*globFun_mon->create) ("Spikey Subdivide", NULL);
    if (dat.mon)
    (*dat.mon->init) (dat.mon->data, dat.count);
    * We will alter polygons in the primary layer only since we
    * can only create new data in this layer.
    err = (*op->polyScan) (op->state, Subdivide, &dat, OPLYR_PRIMARY);
    * End the monitor whether we completed successfully or not.
    if (dat.mon) {
    (*dat.mon->done) (dat.mon->data);
    (*globFun_mon->destroy) (dat.mon);
    * Complete the operation by calling `done.' We pass the error
    * code if there was one, or NONE. We also want to select any
    * new data if there was data selected to start with. This is
    * important for maintaining the user's idea that the same stuff
    * is selected even though we replaced each polygon with several
    * new ones.
    (*op->done) (op->state, err, EDSELM_SELECTNEW);
    return err;
    * MEDIT.C -- Spikey operation as a mesh-edit command.
    * Main entry point for mesh operation.
    XCALL_(int)
    Activate ( int version, GlobalFunc *global, MeshEditBegin *local, void *serverData )
    MeshEditOp *op;
    double factor;
    * Check interface version.
    if (version != LWMESHEDIT_VERSION)
    return AFUNC_BADVERSION;
    * Get global data -- monitor and xPanels functions.
    globFun_mon = (*global) ("LWM: Dynamic Monitor", GFUSE_TRANSIENT);
    if (!globFun_mon)
    return AFUNC_BADGLOBAL;
    globFun_pan = (*global) (LWXPANELFUNCS_GLOBAL, GFUSE_TRANSIENT);
    if (!globFun_pan)
    * Attempt to begin edit operation. If the startup fails we still
    * return OK, but just don't do anything.
    op = (*local) (0, 0, OPSEL_USER);
    if (!op)
    return AFUNC_OK;
    factor = 2.0;
    Spikey (op, factor);
    return AFUNC_OK;
    * Globals necessary to declare the class and name of this plugin server.
    //char ServerClass[] = LWMESHEDIT_CLASS;
    //char ServerName[] = "LWMakeSpikey";
    static ServerTagInfo srvtag[] = {
    { "Bullet", SRVTAG_USERNAME | LANGID_USENGLISH },
    { "create", SRVTAG_CMDGROUP },
    { "objects/primitives", SRVTAG_MENU },
    { "Bullet", SRVTAG_BUTTONNAME },
    { "", 0 }
    ServerRecord ServerDesc[] = {
    { LWMESHEDIT_CLASS, "Bullet", Activate, srvtag },
    { NULL }
    Current system Specs:
    4gb ddr2 1066
    dual 9600 gt (512mb each) running SLI
    9600 black edition amd
    780a nvidia chipset
    XP Pro or XP Pro 64 or Windows 7
    Unknown Cavern
    930
    Here is the spikey.h file:
    * SPIKEY.H -- Spikey modeler plug-in header.
    #include <lwmeshedt.h>
    #include <lwpolygon.h>
    #include <lwxpanel.h>
    #include <lwdyna.h>
    #include <stdlib.h>
    #include <string.h>
    #include <stdio.h>
    #include <math.h>
    extern DynaMonitorFuncs *globFun_mon;
    extern LWXPanelFuncs *globFun_pan;
    extern int Spikey (MeshEditOp *, double);
    4gb ddr2 1066
    780a nvidia chipset
    Unknown Cavern
    930
    HA! It's amazing what done does... or doesn't do.
    4gb ddr2 1066
    780a nvidia chipset
