Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Registering another platform for LightWave 9.x
    Pessac
    5,033
    If you want to change platform with LightWave - to go from 32-bit Windows to 64-bit, or to Mac from PC or vice versa - then you need to generate a new license.key for your machine. Here are the steps involved:
    1. Login to the Registration system at http://register.newtek.com;
    2. Go to My Products;
    3. Copy the serial number from there;
    4. Go back to My Home and register a new LightWave 3D;
    5. Paste the serial number you copied and you will be presented with a page where the licence you already registered is filled in, but there are empty cases for the other two platforms. Make sure you verify that the dongle number is correct for the platform you are registering.
    B
    LightWave 3D Trial Edition
    Thanks for this valuable thread!
    ____________________
    Human Resources
    Super Member animotion's Avatar
    NY
    979
    BeeVee, can I use my paralell dongle if switching over from 32bit to a 64bit system that does have a paralell port? Or am I going to have to get a usb dongle?
    Pessac
    5,033
    Yes, you can use a parallel dongle. Just get the standard 7.4.0 release of the drivers from http://www.setupmykey.com - the one driver contains 32- and 64-bit versions, plus parallel and USB versions too.
    B
    Newbie Member AreDub_3D's Avatar
    Oct 2007
    Hong Kong SAR
    28
    Ben, is this also how you would do it if you wanted to be able to run LW on two Macs (not simultaneously)?
    I haven't even tried yet, but eventually I'd like to use it on a workstation when at home and on a laptop when traveling.
    Do I need to do all this, or just use the same license key?
    3D Entertainment Artist StormRising's Avatar
    Apr 2004
    Austin Texas
    102
    Hey I'm about to set-up my new CPU with windows vista 64x. Any comments on what I may need to know about Lightwave 64x etc.? Does anybody know if Fprime 32bit will work in my 64bit LW?
    Measure twice and render once.
    Pessac
    5,033
    There is a 64-bit version of FPrime available if you have the 32-bit one already. If you want to run the 32-bit one, you'll need to install the 32-bit version of LightWave on this 64-bit machine (which you can also do).
    B
    Apr 2004
    Austin Texas
    102
    Can I use my USB dongle and just plug it into my 64x cpu? or do I need 64x dongle driver?
    Newbie Member Jonu's Avatar
    Oct 2007
    Kuala Lumpur
    19
    Sticky!
    Thanks! That's great!
    251 01 251 02
    251 03 251 04
    251 05 phone-lookups
    989 01 989 02
    989 03 989 04
    989 05 phone-lookups
    Oct 2007
    Singapore
    2
    Lightwave 8.5 PC version
    Recently, I just bought a new 64bits computer machine running on window XP 64bits. Can i able to run lightwave 8.5, paralell port dongle on this new machine. Or do I need to change the dongle for 64bits?
    Dia
    Pessac
    5,033
    Yes you can continue to use a parallel port Sentinel key.
    B
    why my Mac said the dongle is not found using LW 9.
    My Mac running Dual 2 GHz PowerPac G5 with Version 10.4.11
    what should i do???
    Dec 2008
    Chicago
    10
    Dongle drivers maybe?
