Thread: render Spherical Map
    Respect The Architect Limbus's Avatar
    Bremen / Germany
    1,232
    how would I need to setup the advanced camera (or any other camera) to render out a 360° image with spherical mapping (example here: http://www.dosch.de/produkte/hdri/Nature_V1.html)
    Cheers, Florian
    3DGrafikvonBehr
    Sys: 2x Mac Pro, 8x 2.8 Ghz, GeForce 8800 GT, 10 GB RAM, Mac OS X 10.5.5 and Vista Business 64
    NewTek Developer jameswillmott's Avatar
    Dec 2004
    Gold Coast
    3,171
    I think Advanced camera, Horizontal FOV set to Cylinder, 360°, Vertical FOV set to Cylinder 180° should do it.
    LightWave3D training, assets, news and discussion at www.liberty3d.com
    My opinions are my own and do not represent the opinions of any other entity, Liberty3D is not officially endorsed by NewTek.
    Bremen / Germany
    1,232
    Looks good, Thanks.
    Florian
    3DGrafikvonBehr
    May the sauce be with you starbase1's Avatar
    London, UK
    5,585
    I stuck a preset for this on my downloads page too...
    See below!
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    Bremen / Germany
    1,232
    Quote Originally Posted by starbase1
    See below!
    Thanks!
    3DGrafikvonBehr
    Bremen / Germany
    1,232
    Quote Originally Posted by jameswillmott
    In my tests the setting should be 360° for both directions. That way it looks allright when used as a background map.
    Florian
    3DGrafikvonBehr
    Rock'nRoll Set Visualiser Adrian@Stufish's Avatar
    London, UK
    452
    's a wierd one - LW seems to expect a lightprobe image that's a 360wrap, but the way it maps if you use that from a camera pointing straight up for a backround/luminosity source, then you are only using the 'information' from about the centre quarter of the image (AKA above the horizon - the bulk of the image is underground. so in order to avoid a stupidly big image map that is 75%+ useless, you have to use a 180 map and map that as a planar (Y) mapping onto a halph sphere - this of course inevetably smears the horizon - which is the bit the camera is most likely to be pointing at!
    Anyone worked out a way to use the camera to make a spherical wrap image that looks like a rectangle spraed at the poles & maps the same as all the other LW spherical maps - at least that way only half the image is useless and the horizon has the least shrink&re-spread!
    It's only Rock & Roll, but it pays the wages!
