Results 1 to 10 of 10
Thread: Dynamics Calculate Crash
    Jun 2006
    Calgary
    28
    Hi, I can usually find the answer to my problems by reading the forum (long time viewer, first post, thanks for all the help!) but can't seem to find anyone with this same problem. While calculating a cloth simulation everything locks up if I do anything other than move my mouse or hit ctrl (which properly aborts the simulation). Even if another program pops up a window, everything locks up. This even happens after a full format and reinstall.
    Animation Monkey iconoclasty's Avatar
    Jan 2006
    Michigan
    926
    What version are you using? I know dynamics calculations had this issue which was cleaned up a little in v.9 I think. It's not anything that's wrong with your system or anything, it's just a natural reaction from layout I think. However, are you sure it's completely locked up? When I've had this issue before it would only lock up until the calculation was finished, then it would come back.
    Friends come and go, but enemies accumulate.
    state of confusion
    6,973
    Altho this is your first post and I was tricked on another thread...you asked something LW so
    My calculations take up to hours per frame and the CTRL key is not checked by computer untill frame is complete. This was discussed in a hair dynamics thread.
    It's not locked, but calculating.
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Jun 2006
    Calgary
    28
    iconoclasty I'm using 9.2.
    prospector Not too sure what you meant by "tricked". Just curious
    I brought the scene down to 10 frames and it does keep calculating, as it completes the 10 frames. Only thing is it won't let me stop the calculating with the ctrl and the frame and step information doesn't change. The frames are taking less that 10 seconds to calculate and I'm constantly trying the ctrl key.
    Thanks for your help so far.
    Jan 2006
    Michigan
    926
    Yeah, if you press any other buttons or switch to another program whilst calculating the interface is going to lock up until calculation in complete. I don't think anyone's found a way around this as of yet. If it's causing you difficulties the only thing I can suggest is to bring your timeline down to as few frames as you're going to want to see calculated while you're tweaking the dynamics.
    Jun 2006
    Calgary
    28
    That's too bad that happens. Seems like something that should be fixed. Thanks again for your help.
    Jan 2006
    Michigan
    926
    there was talk of a control window that would allow you to switch to other programs and I believe keep LW from locking up. It was suppose to be new in 9 and I thought I even used it a couple times but it seems to have disappeared.
    Jan 2006
    Michigan
    926
    Okay, here's another solution. open FX browser (under utilities tab-plugins-additional) If you use that to calculate (by pushing start) it doesn't have the locking up issues and there's an easy to use abort button. I hadn't used this previously but it seems to do the trick.
    Jun 2006
    Calgary
    28
    Thank you very much iconoclasty, you've just made my life a lot easier! So far it works great.
    Jan 2006
    Michigan
    926
    No prob, learned something myself in the process.
