Thread: Omega object inside double-sided transparent object?
    3D Mac Maniac Scazzino's Avatar
    Boston area
    2,554
    Question Omega object inside double-sided transparent object?
    Has anyone been able to use an object with the omega shader inside (or behind) a transparent object that's double-sided?
    I'm getting shading artifacts on the omega surface as seen in this test. The same thing does not happen if I use Kappa or Sigma instead, but Kappa doesn't look as good and Sigma doesn't let me control the specular the way I like...
    MikeS [LWProfile] 30+ Yrs of Award-winning Media DreamLight.com
    Drag-and-drop-dead-easy™ ScreamerNet - DLI Constellation
    BOOK - Creating a 3D Animated CGI Short & 3D CGI Short Films & DLI Blog
    Boston area
    2,554
    The artifacts I'm talking about are the triangular facets that appear on the enclosed larynx, trachea and thyroid... turning off double-sided on the enclosing neck/torso object gets rid of them, but then I can't use the neck/torso to cast shadows onto the enclosed objects...
    Anyone have a workaround?
    Ze Engineer connerh's Avatar
    Jul 2005
    Charleston, SC
    419
    What all are your settings in Omega? Are you using single or multiple scattering, how many recursions, etc?
    Boston area
    2,554
    It doesn't seem to matter. Here's the stripped down scene with the node map. I've tried changing every setting. Whenever I turn on the transparent torso object, it messes up the Omega surfaces of the cartilage and trachea inside. The outer transparency seems to mess up the handling of the double-sided polys in the Omega surfaces...
    I even tried replacing my cartilage surface with the greenish Omega surface posted from this thread, which had the same problems when inside the torso transparent surface...
    I'm going to run a test with real air polys instead of using double-sided with the spot-info/switch to see if that might work better.
    Attached Files Attached Files
    Boston area
    2,554
    Using real air-polys rather than double-sided/switch didn't help either...
    Mar 2007
    UK
    688
    Well I notice your not using a switch node, but are blending materials.
    I imagine this is part of the problem. Use a switch node instead of the material mixer node. My 2p.
    Boston area
    2,554
    The problem was a bug that's been fixed...
    Here's the finished illustration and animation...
