Results 1 to 2 of 2
Thread: Freelance: Highres charactor modeler needed
    CPH, Denmark
    281
    I'm in the need of a highres modeler for a freelance job - your task will be to model a statue with accuracy and detail in mind. I can't show anything yet as the photos has to be taken, but you can have a look at provided links to get a clue:
    http://z.about.com/d/dc/1/0/j/LincolnMemorialStatue.jpg
    http://www.seeing-stars.com/ImagePag...sStatue1.shtml
    http://www.jeffersonhistoricalsociet...rsonStatue.JPG
    These pictures gives a good idea about the overall look and amount of detail I'm looking for - just to make it more clear, I can add that I'm not interested in this style:
    http://www.bartellonline.com/shangha...lai_statue.jpg
    http://thesims2.simshost.com/images/...ton_statue.jpg
    Both are too clean and lack that old statue/hand crafted feel to them.
    The model have to be in LWO format, however you may use ZBrush - in which case I will need the ZBrush project file as well - If working in ZBrush, then it's important that the model is Lightwave compatible: working UV's and displacement map for lowres version.
    The model will need to have a fixed (sitting) pose - no need to prepare it for rigging or any kind of animation at all.
    This is all the information I can provide atm. If interested then feel free to send me an e-mail, telling me what you expect in return, and how much time you would need to work on the mode - you can base it on this: http://z.about.com/d/dc/1/0/j/LincolnMemorialStatue.jpg
    Your quote and time estimation will of cause only act as an indication to get things rolling.
    I will need to see at least 3 highres and realistic charactor modeling samles from you with shaded/rendered and wireframe views.
    World is carzy I'm not jesusguijarro's Avatar
    Spain
    344
    Hi Zafar,
    I'm interested in the job, where can I send you a private message? You can contact me at [email protected]
    Regards
