Thread: Aspect Ratio conundrum
    Mar 2007
    Hartley Wintney, Hants UK
    77
    Simple question, I just can't get my head around it...
    I export PAL Widescreen from LightWave (720 x 576, aspect 4.222). I import it into an After Effects project set up at D1/DV PAL Widescreen 720 x 576, aspect 1.42).
    Why does my LightWave frame not fit exactly the project canvas area, instead of being far too short on the width? And how do I fix it?
    Thanks brain-boxes!
    LW Board Lurker Extent's Avatar
    Bay Area, CA
    344
    You've got the wrong aspect ratio in your LW scene, looks like the decimal got offset somehow. If you match aspect ratios the files will move straight across. AE is just doing what you tell it to.
    "I am interested in entertaining people, in bringing ... laughter, to others, rather than being concerned with 'expressing' myself with obscure creative impressions" -Walt Disney
    Levanthia.com
    Mar 2007
    77
    Ooops - sorry I meant the LW aspect is 1.4222 (720 x 576), the AE project is 1.42 (720 x 576) but when import the LW frames in, they do not fit (widthwise) the AE canvas area by a long way...what to do?
    Bay Area, CA
    344
    Hmm, well are you rendering as an image sequence? AE is probably importing the images as square pix. Check if you have a footage info window and see what aspect AE thinks the footage is. If it says 1.0 then you need to find "Interpret footage" or whatever it's called in AE. I'm pretty sure in Premiere you can get to it by right clicking your footage in the bin. Then you just have to force the sequence to the correct aspect and framerate.
    Levanthia.com
    Mar 2007
    77
    Well, I've now exported the single frame from LightWave as 1024x576 with a 1:1 pixel aspect ratio. This imports into AE correctly for the project set at 720x576 pixel aspect ratio 1.422, so I think I was overdoing the 'squeeze' twice unwittingly.
    Thanks for your help.
