Thread: My particles don't show up in render-n00b
    May 2007
    Florida
    2
    I am a n00b so I'm missing something simple. Whenever I try to render a particle animation (including those in the Content disc scenes)...nothing shows up in the render. I am following some tutorials, the particles do what they are assigned to do in the Layout screen...they just don't show up in the render. Thank you in advance for your time and advice.
    What was the question? PointC's Avatar
    May 2007
    In My Own Little World
    119
    Is your emitter set to Partigon or HV? Partigon will generate single-point polygons which you can see in a render, but you'll need to add the hypervoxels volumetric to an HV emitter to see them in a render. Press Ctrl+F6 to get to the Volumetrics options and choose HyperVoxels from the Add Volumetric menu and that will give you access to your emitter. From there you can surface your particles. Using VIPER can really help in surfacing. Hope that helps. Cheers.
    If you travel the straight line from Point A to Point B, just keep going and you'll find Point C
    May 2007
    Florida
    2
    Thank you PointC, yes, indeed, it helped alot.
    Jun 2007
    Houston
    2
    I too am new to LW. I am rendering a semi-transparent object and inside, i have a particle animation. If i turn Ray Trace transparency on, i see the particles perfect, but the transparency has a checkerboard effect. If I turn OFF RayTrace transparency, the transparent object looks perfect, but the particles are not visible. Do i have to have RayTrace on to see particles? Any ideas?
    Many thanks in advance.
    Jun 2007
    Houston
    2
    Nevermind. It is amazing what you can find out if you just do a search of the forum. Anyway, just switched to Perspective camera.
    Alls well
    May 2007
    119
    Glad to hear all is well. Cheers.
