Results 1 to 15 of 17
Thread: Tron Electric Lines Effect?? glow effect
    Dec 2006
    uk
    15
    hi,
    I have been using the "Tron Electric Lines Effect" video tutorial from Newteks website in hope of getting the glow effect on my 2 point polys. i have turned the glow effect up on the surface but no hope, does anyone know of any other step by step tutorial on how to achieve this effect, how have a preset surface that they could send me.
    Thanks in advance
    Stav
    don't forget to turn on glow in the post processing tab (see screenshot)
    www.bytehawk.net
    1 : Imac 27’ I7 mid 2017 8Gb ram
    Dec 2006
    uk
    15
    excuse the stuipidity
    glad to be of help.
    not with the stupidity, but with the advice
    www.bytehawk.net
    http://erikalstad.com/Thank_You_Shif...mageFilter.htm
    just though it was a bit related so posted it : )
    Where is that effects window?
    Where the heck is that window? How do you get to it, please? I'm talking about the effects tab you were showing someone regarding the glow.
    press ctrl+F8
    www.bytehawk.net
    Wow, great. Thanks! Now, is the processing on that relative to a certain line, or object?
    Like, say I have a cube, I want it to glow, and I turn up the luminosity in the surface window. Its bright, but is'nt 'glowing', does this effects widnow make it glow? And if so, how is it making only the cube glow, and not other things that are luminous? Because I want to make it sensitive to only certain objects or surfaces.
    nonono
    you need to increase the glow intensity on the advanced tab in the surface editor, not the luminosity
    www.bytehawk.net
    But if I want the surface to be lumious, and therefore give off a glow, then thats ok, right?
    it's not going to glow because you up the luminosity, but if you want the surface to be luminous, yeah sure.
    www.bytehawk.net
    But to justify the glow, it has to come from a source. So thats why I would raise the luminosity of the surface.
    trying to get to effects window!
    Hi Bytehawk,
    I tried pressing ctrl+F8 but I got my volume control. I'm on a Mac, trying to get to the effects window to attack the glow effect. Is there another way?
    see animgif
    www.bytehawk.net
    Wow! Thats great. Thanks! But how do I assign the glow to a particular surface?
