Results 1 to 2 of 2
Thread: got a weird problem with layout
    Newbie Member Ewoodward3's Avatar
    Mar 2007
    New Jersey
    3
    I'm creating a cartoonish serpentine character, with a long neck and tail. the neck is constructed in segments because the bones did horrible things when i made it a single tube.
    now i've built the character with bones, and again using layer/pivots for the movement, but in both cases none of the segments will stay moved when I adjust them in the layout.
    the neck will bend, one segment, but when I try to bend a second segment the first snaps back to it's original position.
    why is this happening? and how do I make it stop so I can?
    "Imagination is more important than knowledge" -Einstein
    "Good, because I know nothing." -me :help:
    Gribbly's Day Out flakester's Avatar
    Dec 2004
    Birmingham
    1,002
    There are three buttons underneath your time slider in Layout.....
    Make sure the top one 'Auto Key' is checked. (As in, highlighted)
    If you don't have this set to 'on' - you will have to manually set a keyframe for everything you move/rotate/scale, at the frame you move/rotate/scale it.
    Hope this helps.
    flakester.
