Thread: How to sort lights, cameras, objects, ...
    I know that I used "manual sort" from time to time, but is there now a new way to do this in layout as the object ID system totally changed? Hate to scroll through all the lights when I just want certain one. If I could rearrange their order it would be great.
    Also is there a way to prevent items (e.g. bones) to pop up in the "parent to" dialog field? If you just want to parent objects to objects it's hell to scroll throught hundreds of bones you don't need.
    state of confusion
    6,973
    could use the amazing and indespensable spreadsheet, which sorts stuff to your setting and saves the settings, then all stuff is showing and no need to scroll.
    It's been fixed so it doesn't crash anymore and is open whenever my layout is open.
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Hastings, New Zealand
    7,731
    Dont forget the flyout panels for each item either.
    Flyout panels? Is that a spreadsheet feature?
    Never used spreadsheet before. Is it worth a try?
    Or, what is it best used for which "Current item" and "Scene editor" can't do?
    state of confusion
    6,973
    Almost every attribute can be edited globally in spreadsheet after multi selecting.
    Sager
    12G 1600mhz mem
    Well, I'm curious whether I'll bite my own ***** when reading more about it in the docs...
    7,731
    Quote Originally Posted by Thomas M.
    The flyout panels are the tiny little buttons next to the 'current item' button at the bottom of layout. Theyre like a mini spreadsheet for each type of item LW supports.
    I also agree that the scene editor is very powerful.
