Thread: Stupid newbie question
    LW Noob
    Nov 2005
    Colorado
    23
    Okay, I've been using Modeler for a while now and I need to do something that I can't figure out. I want to select all polygons that are using a specific surface. Is there not a built in command that does that?
    state of confusion
    6,973
    in poly mode (bottom left side of interface) there is a button called polygon
    click that > hit'w'
    about halfway down there is a line called surfaces
    click and pick surface you want then hit the '+'
    your surfaces with that name will highlite
    Skype...lost_in_3d_space
    Sager
    I7-4800 OC'd to 3.3 GHz
    12G 1600mhz mem
    256 gigs raided SSD drive
    Stuper Member
    PA USA
    1,043
    If you look at the Polygon Statistics panel towards the bottom there is a Surf entry with a downward arrow you can click to select a surface. Then click the + sign.
    LW Noob
    Nov 2005
    Colorado
    23
    Thanks for the help, both of you. I really appreciate it. I've never had to do it so I had no clue where to look.
