Thread: Start point, End point => Direction
    Super Member vashts's Avatar
    Tornavento, Italy
    365
    hi all, question: how can I obtein the direction (vector) from a start point to an end point? I need to give the result as input of the raycast node..
    vashts
    My website: Geba.it
    LightWave Italian Community: LWITA.com
    Tornavento, Italy
    365
    I reply to myself.. as I thought, given point A and point B, the direction from A to B is B - A.. so, I may use a subtract (vector) node and put the ending point in node's A input and starting point in node's B input.. the output is the input of a normalize node, and that may be the direction I'm looking for..
    ..can you confirm it?
    vashts
    My website: Geba.it
    May 2006
    France
    3,908
    You are correct, a direction for raytrace function is in
    world coordinates, so you need world position.
    Denis.
    Tornavento, Italy
    365
    ok, but it doesn't work. I've tried to insert a direction (costant) node and its values are in degrees. how can I convert my normalized vector to a direction-like node?
    vashts
    My website: Geba.it
    Tornavento, Italy
    365
    well, I explain better my situation.
    I have a NULL from which I need to trace rays; points hitted by a ray in a defined range are colored with a defined color, points out of that range aren't.
    so, I've added an Item Info node, selected the NULL and used the world position output; I've added a Spot Info node and used World Spot output; those 2 outputs are respectively the input B and A of a Subtract (vector) node. the Result is the input of a Normalize node, whose Result output is the input of Direction of a RayCast node. the Position input of RayCast is given by World Position of Item Info node. the output of RayCast node is the Input of a Gradient node, and so on.
    I think I'm wrong from normalize to raycast: the normalized output isn't in degrees format.. am I right? if so, how to solve it?
    vashts
    My website: Geba.it
    May 2006
    France
    3,908
    the normalization is for having a length of 1 m for the input dir,
    the raytrace functions need always a normalized vector,
    so in the normalize node, the input and the output are vectors.
    The direction is not an angle but a vector defined by 2 point positions,
    (B - A) like you said.
    Denis.
    Tornavento, Italy
    365
    well, at the end it gave me weird results, so I've done in another way.
    denis: what do you think about creating a simple direction node? inputs: starting point, ending points; output: (normalized) direction. all vectors.
    vashts
    My website: Geba.it
