Thread: Block move
    Super Member vncnt's Avatar
    Sep 2003
    Amsterdam
    1,524
    Block move
    I really start to like SpeedEdit.
    But there one keyboard shortcut I still try to find: block move (a Premiere command name?)
    SE does have an option to select the remaining clips (or leading clips) so you could move these clips somewhere else but unfortunately this command does not seem to have a shortcut.
    In DPS Velocity I'm used to this command (key: G) and I use it a lot to create some space on the timeline in order to experiment.
    At age 40 it's difficult to adapt my reflexes for every new package.
    Thanks,
    Vincent
    TC User Group
    Minneapolis
    1,413
    Right click and you will find it on the menu. I don't think there is a keyboard shortcut.
    Ivan
    Dec 2002
    San Antonio, TX
    3,830
    Are these the hotkeys you're needing?
    Select All Previous Items ....................................... Shift + Home
    Select All Previous and keep current selection ...... Ctrl Shift + Home
    Select All Following Items .................................... Shift + End
    Select All Following and keep current selection .... Ctrl Shift + End
    Don't stream it - TriCast it!
    Sep 2003
    Amsterdam
    1,524
    Yess!
    It's not in the F1 help panel but I did found them in the manual.
    Still a bit different than pressing just 1 key, click-and-drag on the first clip to be moved.
    I use this often. New fast feature for SpeedEdit?
    Dec 2006
    That One Place over the Rainbow
    179
    block move was a useful feature on the DPS. However Have you tried using the story board for this? I find it much more useful then the block move feature.
