Results 1 to 13 of 13
Thread: Duel video cards
    Apr 2006
    USA
    20
    Duel video cards
    Hope everyones holiday went well and the new year looks good.
    I have a pc based workstation and am running LW9. My main board has two PCI-16e slots and can apparently run two video cards.
    Perhaps some of you are doing this, and i've a few questions befor I go out and get another card. My current card is a nVidia gforce 6600 and runs fine now.
    Is it worth running two video cards? Is there a big boost in render times of some other benifit?
    Do the cards need to be the same? Can I pair my 6600 with a 7600?
    Thanks for any help.
    Alex
    Super Member avkills's Avatar
    Mar 2004
    Denver, Colorado
    1,363
    I'm not sure you'll see any increase in render times, as LW does not use the GPU for rendering, yet.
    I don't think you can pair mis-matched cards for Crossfire or SLI or whatever nVidia calls it.
    The good thing is that you can dedicated all the memory on each card to 2 different displays which will speed up OpenGL on each display. If you run 2 off of one card, it splits the memory between the two displays.
    But if you want this for a single display, then all you will pretty much gain is OpenGL and DirectX previewing.
    -mark
    Kansas
    1,607
    Render times have Nothing to do with video cards. That's for display only. Newer versions of LW use newer OpenGL features to speed display. As far as video cards a dual display is best by using a single card with two ports, mainly due to driver concerns.
    Malmö, SWEDEN
    7,629
    Little OT here but...
    Is it possible to have four monitors using two SLI-cards?
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    Intel Core i7-4790K @ 4GHz
    16GB Ram
    GeForce GTX 1080 8GB
    Windows 10 Pro x64
    Heir to the Throne RedBull's Avatar
    Apr 2005
    Underground
    1,608
    Quote Originally Posted by AlexHead
    No speed increase in Rendertimes, and NO increase in OGL speeds.
    SLI only works in fullscreen OGL applications, specifically games!
    It will not provide benefit for LW or any other 3D application.
    Yes, they both need to be SLI enabled, and the identicle GPU..
    2x 6800GS for example (same brand, and GPU)
    You also need an Nvidia SLI enabled motherboard.
    It also often is a crappy deal -- lower performance $ than for a single better card, more heat, more driver issues, less space in the computer, time for setting the whole bonanza up and it likely aint very efficient use of power either ...
    Mar 2004
    Denver, Colorado
    1,363
    Quote Originally Posted by Cageman
    I can't speak for Windows specifically, but I don't see why not if each card is capable of driving 2 monitors. You probably have to disable SLI though.
    -mark
    Michael Nicholson zapper1998's Avatar
    spokane washington usa
    4,660
    Blog Entries
    1
    I run 2 Nvidia 7800GTOC's, with 2 monitors, no SLI, and have had no problems.
    I did have issues with the SLI enabled
    Disabled SLI and been smooth sense..
    Intel Core i7-980, OC 4.7ghz water cooled.
    Gigabyte x58-UD3R with an Intell SSD 180GIG
    RamCorsair-DDR3-1600-32GIG
    Nvidia Titan Z, x 2 And 1 GTX-1080 by Gigabyte.
    4xEnterprise/WDVelociRaptorŪ300gig
    Dazed and confused lilrayray77's Avatar
    Feb 2006
    Bucks County, PA
    693
    Im running a single 8800 GTS which is supposed to out perform most SLI and crossfire combinations. It's $400 compared to $600 + for SLI.
    Oh, and it has dual dvi so you can pop 2 monitors in, or a giant monitor.
    -Andy Michaels
    ____________
    PD 2.8ghz - 2gb 667mhz ram - Nvidia 8800 GTS
    Mar 2004
    Denver, Colorado
    1,363
    SLI and Crossfire is basically for games.
    -mark
    Studio Animator DonJMyers's Avatar
    Los Angeles, CA
    563
    I have THREE monitors
    I have two SLI cards running three (up to four) monitors. One glass, two flat screen.
    It's Great! It's like a giant desktop. I have LW on one side, modeler on the other and they share the middle.
    I look at my art on the more accurate glass screen and preview my web page work on the flat screens.
    When you hit "prtscreen" to take a screen grab it creates a huge 3.3K image that looks like cinerama!
    Apr 2006
    USA
    20
    thanks for all the help.
    Dimension the Third voriax's Avatar
    Sep 2003
    Perth Australia
    859
    Quote Originally Posted by DonJMyers
    I have to comment on the media player carefully positioned to cover up a scantily clad .. male/female?
