Results 1 to 8 of 8
Thread: Express yourself!
    Guinea pig in charge stealthoperator's Avatar
    Apr 2004
    Zurich, CH
    38
    Express yourself!
    Hya!
    I have set up a normal displacement for my model. And I want the displacement to be animated so that it looks like it is made of clay or so.
    So I created an expression that randomly rotates my displacement texture (some procedural noise) using the random(x,y) command.
    So far so good. But actually, I don't want the displacement to move every frame. How do I do that?
    I tried to set my expression to something like
    random(0,1)*random(0.0,30.0)
    which should give me about half the times a value of zero. But it doesn't.
    Does anyone know what I could do to make it work?
    Thank you veryvery much!
    Mar 2004
    Cleveland
    312
    Not sure why you would want to use random displacement via an expression when a simple envelope on the rotation channel of the procedural, or even morph maps would be much easier to control.
    Sep 2006
    Future Past Life
    1,897
    Sounds like he's going for a similar technique that Aardman used in "Curse of the Wererabbit".
    I read an article about it in a magazine, you might be able to find it online. I don't believe they used a random generator rather than just a few frames for the displacement map. What you could try is working with maybe five or so frames and duplicating them so that the animated texture only changes every 2-3 frames. So frames 1-2 are the same, 3-4, etc...
    Apr 2004
    Zurich, CH
    38
    Yeah, that's kind of the effect I want to achieve.
    So you suggest just to hand-animate a few frames of the displacement and then repeat the motion?
    Hastings, New Zealand
    7,731
    I would try using the textured channel motion modifier in the graph editor.
    Use a procedural and turn the contrast up pretty high. This will randomly move the channel and keep it on/off for a random length of time due to the contrast setting.
    Apr 2004
    Zurich, CH
    38
    Very cool!
    I did some tests and it looks the way I imagined.
    Thank you!
    7,731
    Good! Post some of your results when you can
    Apr 2004
    Zurich, CH
    38
    I will!
    Right after my hollidays!
    Happy new year!
