Results 1 to 9 of 9
Thread: Modelling a Woolly Rug
    Greytown, NZ
    127
    How on earth would you model something like this long, woolly rug?
    I'm hoping you don't have to model each strand, so is there an easier way?
    Dave
    A thousand years from here
    3,352
    Try Sasquatch?
    I have no special talents. I am only passionately curious. - Albert Einstein
    visit my company site : House of Secrets
    visit my personal site : svenneve.com
    Or you can even use Saslite if you don't own Sasquatch. Use a high Coarseness value on the rug surface plane and a short Fiber length.
    las vegas
    666
    you could use point clone plus. make a grid of points and use a bent cylinder. it would be a high poly count model, but it might work.
    las vegas
    666
    here's a quick 2 minute try with not enough random rotation. 285k polys. you might be able to layer them in layout to get a good effect.
    Ze Engineer connerh's Avatar
    Jul 2005
    Charleston, SC
    419
    if you had HDInstance, you could create a patch, and then clone it.
    If you really want a random look to most of it you may want to make a few sections using Magic bevel to pull out strands, then use Array or Clone tools to arrange them into the rug object then just merge points to make it one object.
    Greytown, NZ
    127
    Thanks for the feedback. I hadn't thought about Saslite, so I'm going to give that a go - thanks Red Oddity and JamesCurtis for the brain refresh.
    If I can't get that to work nicely, then I'll try pdrake's idea and use point clone plus.
    Thanks again.
    Dave
    Hastings, New Zealand
    7,731
    You can also subdivide the mesh and apply a displacement map to it.
