Thread: Animated Image Map not Rendering
    Truly Gone Fishing h2oStudios's Avatar
    Jun 2004
    NY
    552
    I've used animated quicktime .mov's and .avi's as textures on geometry before and they worked and rendered fine. After switching machines for some reason they don't render. They show up in OpenGL but when I render the image it's just the base color without the texture, they don't even show up in the Surface Properties panel preview. I'm not sure whats wrong here.
    h2o
    Check the files in the Image editor, sometimes they will have Alpha turned to Enabled, even when there is no alpha, so it assumes it's blank, which mattes out the whole image. Just disable the alpha.
    Confirmed -
    Jun 2004
    NY
    552
    Thanks, I'll try this, hopefully thats the issue.
    Jun 2004
    NY
    552
    Yes it was, thanks again toby.
    h2o
    I was hoping that wasn't it, it's such an old bug.
    Confirmed -
