Results 1 to 10 of 10
Thread: Really Need Help w/ Boolean Subtract
    Apr 2006
    texas
    31
    I'm trying to model the attached object... My first thought was to model the main yellow shape in basic form then I tried to build the little shape that is "knocked out" creating the hanging hole. When I boolean subtract this shape from the main yellow object, I'm left with all kinds of 5+ polys...
    Bottom line is how would you guys go about modeling the "hanging hole" of this object..??
    thanks in advance
    I would do the shape of the inner filter as a profile. Make the shape and extrude that shape to fill the yellow object.
    LW Board Lurker Extent's Avatar
    Bay Area, CA
    344
    I'm sure there's a better way, but I would just boolean them out and do cleanup by hand, which usually involves merging the booeaned object, then manual welding of points, trippleing 5+ polys then manually merging the subpatched object and genrally correcting poly flow.
    "I am interested in entertaining people, in bringing ... laughter, to others, rather than being concerned with 'expressing' myself with obscure creative impressions" -Walt Disney
    Levanthia.com
    Apr 2006
    texas
    31
    heres a screenshot of what I tried yesterday....
    basically this is the intial object that was subpatched then freezed and then built an object from which I did a boolean:subtract...
    does this look right?
    Unsure as to which piece was giving you trouble but here are some thoughts...
    I edged extruded one side, centered the center points then mirrored it.
    Then, I did a profile of the inner part based on a background image; extruded it to the 0 X location; then mirrored it.
    Moved some points up to better match what it was I saw of the pic.
    Then, went back to the yellow part and multi-shifted, twice, the top and bottom areas where the keyholes are. The second shift I deleted leaving a hole. Shaped the hole to resemble a key.
    With more work, I would sub'd this puppy for a smoother look.
    An image to go with these thoughts and the object.
    Thanks for asking the question. I was bored.
    Attached Files Attached Files
    Apr 2006
    texas
    31
    wow, thanks for doing so much to help and I'm amazed you were able to pull so much from the image...
    heres the file that was pictured in my last attachment... I'm just worried about the key hole at this point....
    How does this look?
    Looks good. But don't focus on the keyholes as they ought to be close to the last thing you do on your object. Make sure you have your form set up first. Also, make sure you have the important part of the object properly placed within the less important part; i.e., the filter is the most important part of this object, I would think, so its placement is as important as the keyholes.
    That said, your keyholes look great. Show us a render when you get it all done, please.
    Apr 2006
    texas
    31
    here is an early render.... I want to continue adjusting the "filter" paper to look less manufactured. And theres some problems at the bottom of the paper where it meets the plastic... Im happy with it so far though.. (I know the lighting is crap, just through that together to see what I was looking at)
    thanks
    Cool. Lookin' good.
    So, are you doing it in subds or just polys?
    Apr 2006
    texas
    31
    polys.... I'll get you a wireframe later....
