Results 1 to 2 of 2
Thread: Gradient using distance on displacements
    Lightwave rebel Pensart's Avatar
    Belgium
    291
    Hope the title is a bit clear. I was stuck a while back when i wanted to color an object with a color gradient based on the distance of his displacement map. So i started a thread and got a very good tip thanks to "Toby".
    You can read all about it on the next hyperlink http://www.newtek.com/forums/showthread.php?t=59488
    Since i'm pretty sure that this question will repeat so i decited to post my result in this area.
ID:	39136   Click image for larger version.
ID:	39137   Click image for larger version.
    Joined the Rebellion
    Belgium
    291
    Please keep in mind to set the bump value to 0 since we dont want extra bumping on the object!
