Thread: graph editor disappears
    Jun 2003
    london uk
    5
    Angry graph editor disappears
    Can anyone help......for some reason now if I try to start graph editor the window appears for a split second and then disappears and is inaccessible. |All the other editors are fine
    Registered User Meaty's Avatar
    Arlington, VA
    458
    if you recently updated, try saving your menu configurations, if they are configured in a special way. Then delete the Hub generated config files. Reload your menu's and that should fix the problem.
    Chris Moschella
    ****** korn_kid's Avatar
    San Fernando valley, CA
    122
    I had the same problem,
    just delete all of your LW's .cfg files.
    then reload your plugins.
    01001011011011110101001001101110001000000111001001 110101011011000110010101111010
    Stuttgart, Germany
    13,585
    Easier than that:
    close LW
    find your lw3.cfg
    delete the line containing "EnvEd_Options"
    open LW
    If you have problems with your previews delete the "PreviewOptions" line.
    No need to thrash your config.
    Somehow LW writes garbage there sometimes, so deleting those lines will result in the default options being used.
    I haven't had any of these problems in 7.5c though.
    Cheers,
    Mike
    Arlington, VA
    458
    ahh, so THATS the line causing problems... good stuff Lightwolf
    Chris Moschella
    Stuttgart, Germany
    13,585
    You're welcome... please excuse the lousy spelling though (...wanders off to edit...).
    Cheers
    Mike
