Results 1 to 15 of 15
Thread: RLA/RPF Export?
    Angry RLA/RPF Export?
    Hi, I am having zero success exporting RLA/RPF data. I have the Object ID and Material Buffers selected but when I try using it in Discreet Combustion and try to switch out the texture it looks like only every other vertical line gets replaced.
    Anybody have success with this process?
    LW 7.5c
    Discreet Combustion 2.1
    Mac OS 10.2.6
    Gold Member Beamtracer's Avatar
    Citizen of the World
    2,226
    It seem to work in Adobe After Effects, as long as it's set to 8bpc mode. When it's set to 16bpc the image gets scambled.
    Sorry, I can't say how it's done in Discreet Combustion.
    Hi BeamTracer,
    Would you please post the steps you did to get the Material ID and Object ID to export as RPF data. Besides setting the "Extended RPF Export"plug-in under Image filters did you set-up the material IDs anywhere else (e.g., special buffers in the surface editor) or have to setup UV maps. I am getting z-buffer info out correctly, but not material or object ID.
    I have a contract where I have to swap out tons of texture for multiple passes of the same animation. I need this to work, even if it means buying Afer Effects.
    Thanks,
    Ari
    Student of Life mwh710's Avatar
    Las Vegas, NV
    135
    tried to delete, but can't
    2,226
    Hi Ari. Well, I don't use these features very much, as it's limited to 8bpc, and doesn't work with 16bpc. Also, you must keep anti-aliasing on, as the object and material channels get corrupted when anti-aliasing is off.
    Because I'm not doing it all the time, I'm a bit hesitant to recommend After Effects for this purpose, but maybe it is what you need.
    I loaded up a couple of primatives into Lightwave 7.5 (OS X), then rendered out an RPF file, using the Extended RPF plug-in in Lightwave's image filter section (not the render menu).
    Then I brought the image into After Effects 5.5 (OS X), and applied the 'Extract 3D' filter (in the effects menu).
    The results are below.
    Moral of the day:
    Worry about your own morals, not someone else's!
    2,226
    Here are a couple of primatives, and this is the normal RGB image.
    2,226
    Here is the object ID channel, extracted by After Effects:
    2,226
    Here is the material ID channel, extracted by After Effects:
    2,226
    I forgot to mention that you need After Effects Production Bundle to do this. I don't think the standard version of After Effects has the 3D filters.
    You could probably use AE's 16bpc mode by rendering to 16bpc PSD images in addition to 8bpc RPF files, though AE will throw up warning messages about your image depth.
    Also note that After Effects 6.0 is due for imminent release in days or weeks.
    Below are AE's 3D filters:
    Moral of the day:
    I would never have thought. Since I was just setting up test cases l left AA to none. As soon, by your recomendation, I turned AA to medium Combustion worked just fine with RPF data.
    Thanks much for your help,
    Ari
    sweden
    142
    I got RLA and RPF to work in both Combustion and AfterFX, but not in Shake
    It's perfect for creating fast rendered DOF and fog effects.
    It's, strange that it doesn't work in shake.. maybe I do something wrong..
    Yep, DOF and fog alwas worked great for me in Combustion, but this time i have to swap out tons of texture maps. I never did that before and it did not work as expected. Once AA was increased it seems to work just fine.
    Question for you on DOF. I have always used box blur because gausian blur does not seem to work. have you had any succes with gaussian blur for DOF?
    sweden
    142
    Actually I don't remember what type of blur I used, it was a long time ago and I don't work at the company that had Combustion any more.
    2,226
    Lucky Shake user!
    Notice he said it DIDN'T work in Shake.
    What's so lucky about that?
    Cheers,
    JS
