Thread: scene editor disappears!
    Hello,
    I am in 8.2....It only seems to happen with one particular scene of mine. I load the scene and hit "open scene editor" and it appears for a mili-second then disappears. But if I ask for the classic scene editoe it appears and stays around. Any ideas on how to fix that one?
    Thanks,.
    Erik
    I don't use it often enough to have seen that, but I bet that if you open your Master plugins list and delete the scene editor plugin from there and then open a new one it might work.
    I have also seen this kind of thing when there's not enough memory, is it a big scene?
    Confirmed -
    Sep 2003
    Bucks. UK
    860
    I think it remembers where its put- so it may be opening but not very visable if you moved it nearly off screen last time.
    not off screen.....
    Thanks...I will try to erase it from the master plugins list and try that. The scene is big, but I have done much bigger with no problem.
    Erik
