Thread: Different Color Lights
    Feb 2006
    Somewhere
    4
    Is there any way to make an object that only lights up from a light. And Make a light thats different colors. If you can help thanks.
    Ze Engineer connerh's Avatar
    Jul 2005
    Charleston, SC
    419
    I'm not sure I understand your question... The only way to light an object is with lights, unless you're using radiosity, in which case you can just check the "exclude from radiosity" box under the object properties. If you want multiple colors on your light, you'll have to use a spotlight with an image map attached to its projection.
    Aug 2006
    S
    3,511
    A simple question of texture luminosity and the right lighting or else one of excluding the object from the available light sources?
    Leaving Radiosity out to begin with and assuming the lighting is setup in a relevent way:
    Attachment 36220
    M
